Oil Pan Plug
Old 02-09-10, 01:53 PM
Mazenm
Mazenm's Avatar
Default Oil Pan Plug
For the second time the mechanic has told me that the oil pan plug is stripped. He installed an oversize plug which is a temporary fix. Anyone know where I can get a used oil pan? Seems like someone should be able to drill it out and retap for a larger plug??
any ideas would be appreciated.
Old 02-09-10, 10:12 PM
willhickey
willhickey's Avatar
I think its aluminum and thats why you cant rethread it..... Is it the same place that keeps stripping it? If so make them pay for it
Old 02-10-10, 07:41 AM
Mazenm
Mazenm's Avatar
I had a replacement done by a local back-yard mechanic and he installed a used pan. It is the same place (firestone) but they won't take responsibility claiming it was stripped when it came in for routine oil change.
Old 02-10-10, 03:26 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
you cant reallly retap aluminum successfully, better off with a heli-coil.
Old 02-10-10, 03:50 PM
3UZFTE
3UZFTE's Avatar
Just find a cheap used lower oil pan, pretty sure it's steel cause aluminum doesn't like to bend much, as it cracks more easy.
Old 02-11-10, 03:04 PM
steve2006
steve2006's Avatar
Probably didn't replace the sealing washer,had a slight leak and then overtightened the sump plug to attempt to stop the leak and damaged the threads.
Old 02-11-10, 10:36 PM
skperformance
skperformance's Avatar
agreed , you strip it twice and the guy should have known better
Daddylee76
10-30-16 02:52 PM
03RX
RX - 1st Gen (1999-2003)
09-12-11 05:44 AM
actuary
Performance & Maintenance
02-02-07 06:34 PM
ice7
Maintenance
02-02-05 02:00 PM
Quick Reply: Oil Pan Plug
