Parasitic electrical draw help plz :)
Old 02-06-10, 11:06 AM
Zappy
Zappy's Avatar
Default Parasitic electrical draw help plz :)
LS400 1990.
I have got as far as locating it to the DOM fuse in the engine fusebox, but that fuse operates several things within the car, dome light, central locking, truck light, sunroof yadda yadda.
Where do I go from here to isolate things further, the foot-well fusebox has nothing to do with this, so where do things separate?
Or is it a case of ripping stuff out?
Thanks Zappy
Old 02-06-10, 11:39 AM
gtoden1
gtoden1's Avatar
Explain your problem so we can help.
Old 02-06-10, 11:52 AM
skperformance
skperformance's Avatar
look toward the alarm ecu
Old 02-06-10, 02:24 PM
Zappy
Zappy's Avatar
I just did, what further info do you want?
I have a parasitic drain on the battery which I have narrowed down to the DOM fuse in the engine fusebox, but that fuse switches off all the things I listed, so it won't be all those things will it? Yeah, getting it, quite plain.
So what is between the fuse in the engine fusebox and all those items is a lot of wiring, so where, or does all that wiring separate, block whatever to divert to each of those individual things, it must somewhere, if it does where is that block separator, if there is one, or if there is one, is it too impossible to trace there and am I better to start taking the lighting units off etc. I already took off the interior lighting/sunroof control panel and the trunk light, no change.
I think it was clear enough the first time.
Old 02-06-10, 02:26 PM
Zappy
Zappy's Avatar
The DOM fuse has nothing to do with the alarm, that's on a separate fuse?
Old 02-06-10, 03:17 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
lose the attitude, if someone asks you for clarification obviously its because your OP wasn't specific enough.
the DOME fuse controls many electrical functions, so before you rule it out, go check it/try removing it to see if it helps.
what's the point of asking for help then disagreeing/disregarding with everyone's recommendations?
the alarm ecu, and even the trunk hinge wiring have been known to cause battery drain. as have loose terminals.
Old 02-08-10, 09:24 PM
skperformance
Agreed , your asking for help not me . Go buy a wiring schematic if your so smart . Then you might know the multiplex system that crosses over . There are parking lights on one circuit and the alarm controls them also just like it monitors the dome light and trunk light .
BTW saying you have draw is meaningless without the details. What is the amperage draw , constant or variable . So many other inputs needed but you knew that already.
Old 02-08-10, 10:00 PM
frankdms
frankdms's Avatar
^x2 how much draw? If you are confused/lost pm me your number. (I am a tech)
Vitalxs
01-04-17 08:56 PM
primo
RX - 1st Gen (1999-2003)
13
05-18-12 09:49 AM
PW007
08-19-07 07:45 PM
Homchenko
SC- 1st Gen (1992-2000)
08-26-06 10:53 AM
jbbnet
02-29-04 07:56 PM
Quick Reply: Parasitic electrical draw help plz :)
