still cold can i get some help please
Old 01-23-10, 03:41 PM
treeman
treeman's Avatar
Unhappy still cold can i get some help please
I made a post earlier about my car, 94 ls400, i have tried every post i can find on this site and still my kids are cold. HCV, fine; vcv, fine; diagnostic, fine; tstat, new; coolant, full; fuses, good; heater core, clean. Is there anyone that can help me pease.
Old 01-23-10, 10:00 PM
Amskeptic
Amskeptic's Avatar
Have you followed the heat of the hoses to their destination? Do the heater supply and return hoses get hot. Does just the supply hose get hot? Does it not get hot? Does the heater control valve lever actually move through its full range? And can you feel heat flow past the valve as it opens? System properly bled?
Colin
Old 01-24-10, 04:46 AM
lexusguard
lexusguard's Avatar
As Amskeptic said, ensure that the heater core to and return line are hot. If they are than you're heater core is working. The only possibility is that your heater control valve is not opening, just as Amskeptic said. For example, if you jack up the front of your car and turn the heat on it will still blow cold, if you lower the car then the air will become warm, in other words the vacuum that controls the valve isn't strong enough to overcome gravity. Check to ensure that the valve works.
Old 01-24-10, 11:51 AM
treeman
treeman's Avatar
Colin
I have checked heat hoses coming in and out, I did notice earlier today that the HCV wasn't opening all the way. I took cable off and manually did it and still no heat. Properly Bled? I have noticed several ways to bleed the system, how do you recommend
baphomit
Performance & Maintenance
04-13-16 08:25 AM
RalAegidius
38
11-13-12 12:22 PM
chnk
SC- 1st Gen (1992-2000)
17
11-20-11 11:20 PM
treeman
01-23-10 09:56 PM
mvbls400
12-06-09 10:23 AM
Quick Reply: still cold can i get some help please
