2.5LS Newbie needs some helps. (I searched)
Got this 98 LS400 for cheap and it has some minor problems (I hope). Tried to search for answer but couldn't find any, so I'm gonna ask for it.
1. On the temperature control display, my outside temperature keeps saying negative 22 degree F, even when it's like 60. What could be the problem? Sensor? How can I fix that one? Where is it at?
2. On my gauge cluster display, it keeps saying lower washer fluid eventhough the fluid is full. Searched and some say hold the reset, turn the key on II, and hold it til it goes off. Didn't work for me. Found another thread saying I need to check the bottom of the washer fluid bottle and replace the plug there if it's rusted. I'll try that when the weather here get warmer. And confirmation and other suggestion on this one?
3. My heater seems like it's still working. It's blowing and all when I put it on HOT. But, it doesn't blowing hot air out. Only cool air comes out of it. How do I fix this?
4. My serpentine belt was making noise, so I had a shop replaced it. The noise still there now but a little less louder. Should I bring it back to the shop and have them look at it? Or maybe I shouldn't bring it back there at all?
Any informations, suggestions or advices would be greatly appreciated. Thanks and MERRY CHRISMAS AND HAPPY NEW YEAR TO ALL OF YOU.
BahHumBug
2. the windshield washer fluid sensor is basically a foam float and an arm attached to a sensor. over time the foam gets saturated with solution and doesnt really float. easiest way to fix this is unplugging the sensor at the bottom of the windshield washer reservoir, or replacing it out of a junkyard car. i unplugged it as i basically never use the windshield fluid so it never really empties.
3. air bubble in the cooling system, search for it. easy fix.
4. you paid them money and the problem's still there? get your money back (via CC if you need to) and go somewhere else.
please learn to use the search feature more effectively
my heater on my sc400 is doing that ....................... god haha it sucks because its cold haha so im driving the camry with all of its heated goodness. I was thinking it was maybe the heater control valve .
Today, I sat in the car trying to reset the lower washer fluild warning light with the headlight on auto. By the time I tried to restart the car, my battery went low and wouldn't start. VSC off light came on and now, I need to jump my car every single time. I'll take the battery out to AutoZone and have them check and recharge it. Hopefully that would take care of the problem.
Also, I think my AC condensor is leaking. So, should I buy used part, new aftermarket ones on ebay or new OEM one from stealership? Anyone has experiences with ebay AC condensor?
Speaking of noisy serpentine belts . . . the belt is rarely "The Noise".
If you hear crackly noise coming from the front, a light quick spray of glass cleaner will quiet down the "squicking" of rubber as it leaves the pulleys. Then, any remaining noise you can be certain is coming from either an idler bearing or a component that is driven by the serpentine belt.
Colin
Colin
