Brake Pad Selection
Old 12-19-09, 01:17 PM
Thermactor
Thermactor's Avatar
Is there a way to make the MkIV Supra front pads work on the 2LS? If I recall correctly, there was a minor difference which could be corrected.
Old 12-19-09, 01:56 PM
coupdabill
coupdabill's Avatar
Great pads
The hawks hps I put on my 350z (track version) with brembros were great.
Old 12-20-09, 02:19 AM
skperformance
skperformance's Avatar
It is a minor difference from supra to LS pads but they won't swap with minor changes.
LS has no squeal shim , has slot for brake pad sensor , 2 holes on the top rails for the pads to slide completely different form the supra ones . The shape and size are the same .
Not sure if anyone else had this problem but both my front and rear pads busted my brake sensors to **** .
Old 01-04-10, 06:02 PM
JimsGX
JimsGX's Avatar
Update on my search for brake pads...
I installed Hawk HPS pads on the front of my 1st Gen this past weekend. My initial impression is that they are going to work out really well. I had previously installed EBC Red ceramic pads on the front. With the EBC Red's, I never knew what to expect when I hit the brakes. Sometimes they'd stop well, other times not. Pedal feel with them was also sporadic. With the Hawk HPS, the pedal feel is good and very predictable every time I put on the brakes. They also stop the vehicle very well. Much better than the EBC Red's.
I wouldn't recommend using the EBC Red's on a 1st Gen with standard 2 piston calipers. The results on a 2nd Gen LS with 4 piston calipers and larger rotors could be very different from my experience. I'm also running stock rotors. Not slotted or drilled. I tried to get my hands on some EBC Green pads, but everywhere I looked, they were out of stock so I opted for the Hawks.
Jim
Old 02-24-10, 01:51 AM
damon
damon's Avatar
I do not see a Hawk option for 93-94 Models??
Part #'s always welcome:
These are "Red" EBC #'s.
90-92 models EBC- DP3874C Front
DP3876C Rear
93-94 LS EBC DP31006C Front
DP31008C Rear
Old 02-24-10, 04:43 AM
python
python's Avatar
ebc's faded on me when i had the gen 1 setup. but they were the green. hawk is manufactured by a company that first made aircraft brakes. my front pads were supplied by i-rotors when i did my upgrade,they work fantastic with no fading,noise or dust
Old 02-24-10, 07:10 AM
sam12345
sam12345's Avatar
I really like the akobono ceramics I am using. Smooth and progressive. I have brembo rotors. Whatever you do do not use the Toyota/lexus rotors they are pure crap
Old 02-24-10, 01:06 PM
RA40
Super Moderator
RA40's Avatar
Why are they crap?
Mine is on the original factory rotors. At the rate of wear, I'll go beyond 200K miles using the factory pad compound. These have been an excellent combination.
Old 02-24-10, 05:49 PM
J_LS
J_LS's Avatar
I enjoy the akebono ceramics but at a close second centric 105.xxxxx series never gave me any problems as far as brake dust or noise concerns go... centric also has a 100.xxxxx series that supposedly is O.E. pads, not too sure though
Old 02-24-10, 07:14 PM
sam12345
sam12345's Avatar
RA40 maybe I am prejudging the lexus rotors because mine where warpped (when I bought the car so who knows how the previous owner drove it but from the condition and from what I could tell he babied it) and I have a 4 runner warpped rotors, and avalon warpped rotors and a camry (1999) warpped rotors and I had a 2007 camry warpped rotors. This is enough evidence for me to say toyota rotors are crap. Of course all but the 2007 were warpped when I bought the cars used.
Old 02-24-10, 08:22 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what pads are you using...?
Old 02-24-10, 09:54 PM
sam12345
sam12345's Avatar
now I am using akebono but on the ones with the warpped rotors I have no idea since I bought the car with them except for the 2007 and that had all toyota
Old 02-25-10, 08:53 AM
damon
damon's Avatar
Currently I use a plain Bradi rotors (a Brembo company) & Rotex pads.
Just getting a feel for what else is available. Found the EBC Red, Fronts for $84 delivered.
Old 02-25-10, 03:43 PM
Sixdown
Sixdown's Avatar
I nearly always use Akebono, Pagid, or PBR pads for all my cars whenever available. I've found that Akebono seem to last the longest and offer the best performance in ultra-ceramic form. As for rotors, I've stuck to Brembo or Centric premium.
AusTexLex
10-14-11 01:34 PM
MidnightGS
12-19-10 05:25 AM
JBasco20
02-26-10 07:28 AM
kit cat
Suspension and Brakes
21
08-13-09 06:32 PM
indypwr
GS - 1st Gen (1993-1997)
04-04-03 11:16 PM
Quick Reply: Brake Pad Selection
