front end sounds loose
Old 12-09-09, 11:04 AM
2000 ls400
2000 ls400's Avatar
Default front end sounds loose
my car rides smooth most of the time, but sometimes if i hit a quick bump or pothole my front end sounds like somthing is loose and makes a noise. a mechanic told me my shocks were ok. what else could it be? also, should i swap out shocks? thanks.
Old 12-09-09, 11:42 AM
jasonm
jasonm's Avatar
do a search before PD hammers you on the search function.... "strut rod bushings" ball joints and other suspension components.
Old 12-10-09, 02:20 PM
camthman
camthman's Avatar
yup. Search it up.
Old 12-12-09, 10:18 AM
Doc Yota
Doc Yota's Avatar
Had same problem with my 98ls. Strut rod bushings took care of it.
Old 12-12-09, 10:43 AM
kevs98GS4
kevs98GS4's Avatar
If your bushing is bad you need to replace the strut too. For the price of a new strut there's no reason not too, bc your already paying the same amout of labor. I'm assuming with your car being a 2000 it's probably got some miles. Mine went out on my 96 with 165K
Old 12-12-09, 11:08 AM
Garage7RP
Garage7RP's Avatar
That sounds like the strut bushings. GO to 2000 LS400 Strut Rod Bushings
Old 12-12-09, 04:20 PM
2000 ls400
2000 ls400's Avatar
Default thanks a lot
thanks guys, does anyone have a link to where i can find the strut rods also? should i get them from lexus? i am going to try to replace them myself, so any instructions would help too. my car has 110k by the way.
Old 12-12-09, 07:17 PM
jasonm
jasonm's Avatar
Take your time on the site to look around...It's covered a lot. Check out lexls.com. I believe there are a lot of tutorials there.
Old 12-13-09, 12:13 AM
Garage7RP
Garage7RP's Avatar
You do not need to replace the strut rods unless they are bent. You just need to change the bushings.
Old 12-13-09, 01:06 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
except that the only bushings choice you have on 2nd gen cars is a polyurethane ADUS bushing. if you want OEM nvh and feeling, you need to buy complete strut rods since Lexus doesnt sell just the rubber bushings.
Old 12-13-09, 06:31 AM
JimsGX
JimsGX's Avatar
The OEM part numbers for the complete Strut Rods for a 2000 LS400 are:
48670-40011 (LH)
48660-40021 (RH)
You can find them online for roughly $100 each...
Jim
Gumart1
04-04-13 06:56 PM
blazer84
Suspension and Brakes
03-18-12 07:56 PM
oldskewel
03-03-12 02:13 PM
98LSfromNJ
07-26-09 05:05 PM
Quick Reply: front end sounds loose
