Help with 1997 LS 400 audio
Old 08-13-09, 09:20 AM
kc9fjc
kc9fjc's Avatar
Smile Help with 1997 LS 400 audio
Hey everyone,
I have a 1997 LS 400. I love the car. I want to install a new 8" sub in the same factory spot. I also understand that i will need a new amplifier. Can someone tell me a good setup? Like what sub to use and what amp to use? And will all my other components still function as normal? It has Nakimachi. I can spend up to prlly $300 on the amp and sub but would prefer less.
Thanks,
Aaron
Old 08-13-09, 09:33 AM
dashan
dashan's Avatar
1. Sub: JL 8IB4 $100
2. Amp: Alpine MRP-F350 $60
3. Line in converter: $20.
4. Power cable 8 G: $16
Total $196 with $104 left and you can send it to me.
Old 08-13-09, 09:36 AM
kc9fjc
kc9fjc's Avatar
Default thanks
Hey thanks a bunch. And do i really even need to know the wiring diagrams and all that jazz or is it just plug and play.
Old 08-13-09, 09:43 AM
kc9fjc
kc9fjc's Avatar
Can i see some other set ups ppl have too, cuz i cant find those online. Also can i hook up a dual 2 ohm JL sub or would that mess it up cuz the ohms are wrong.
Old 08-13-09, 10:07 AM
BLKonBLK98
BLKonBLK98's Avatar
i'm not going to make product recommendations as it's been covered 1,000,000 times.
what i will comment on:
since the nakamichi system sends a low level signal from the headunit (what amps generally like to see) i would not use a converter. rather, you can just splice the speaker wires into an rca plug and go straight into the amp (i can make this for you if you cannot diy).
impedance is relative to what the amp can hadle and the power your amp makes at what resistance. the "2 ohm rule" is for those who are retaining the factory amplifier and can be disregarded with an aftermarket amplifier.
fyi, the jl *ib4 series has been discontinued for a while. ebay and audio forums are where you might find them.
Old 08-13-09, 10:10 AM
kc9fjc
kc9fjc's Avatar
Default thanks
So i can disregard the 2ohm rule you are saying i can buy a subwoofer of whatever ohm as long as i get an amp that will back it all up?
Old 08-13-09, 10:37 AM
BLKonBLK98
BLKonBLK98's Avatar
correct. just make sure the amp is going to provide the correct amount of power at the ohm load and take into consideration that unless the sub is marketed as "free air" power handling will decrease substantially. at the same time headroom is good, using a lower gain setting with more power on tap to achieve the same power output will keep the signal clean.
foxified
07-20-15 01:57 PM
LuxuryGS3
06-14-14 05:04 PM
SidhuGs300
03-31-14 07:13 PM
Mesca
02-21-12 12:00 PM
DJ SprinklesNJO
13
04-24-02 01:13 PM
Quick Reply: Help with 1997 LS 400 audio
