Problem Removing 96 LS400 Rear Dome Lights
Ok, so I may be the only one with this issue after searching the forums, but is there an easier way to remove the 194 wedge bulbs from the rear dome light housings? I already know to close the door when I'm in the car so that I won't burn my fingers, but I can't seem to grab hold of them. The ones closer to the rear of the car are easily accessible, but the front pair have a reflector which make it harder to pinch the bulbs and pull them out. I've yet to scan through my FSM for a way to remove the entire housing without breaking it, but maybe some of you know of a simple way to remove these bulbs without breaking anything or shorting out the wiring. Any help is greatly appreciated. Thanks!
