92 Ls400 Stays on!!!!!!(ACC)
When i take my key out of the ignition some dash lights stay on and the windows still work but the radio doesnt. When i turn the car on all the lights come on and go off as normal. I have an aftermarket radio and alarm but had both disconnected and checked out and was told that they arent the problem. All fuses are fine and the only thing left to do is go to the dealer ive been told. Mine charges 130 an hour and im willing to pay to fix it but they told me it could take hours and they still might not find the problem which is a lil bit of a waste of almost a thousand dollars. Can anyone help? ive had to disconnect the battery so it wont discharge it and dont wanna risk more electrical problems. It runs SO DAM WELL i dont know how this happened i just found the battery dead one morning and when i recharged it i found out about this problem.
Sounds like you have some type of alarm/remote start combo. If you take the key out of the ignition the engine and all electrical systems should turn off. On my remote start I need to flip a switch to keep the car on while taking the key out, even then it automatically turn off after 10 minutes. I would start taking the panels on the drivers side footwell area off and looking for any non-factory wiring. Also, as trukn1 said, you may have some crossed wires.
I'm going to take a leap here and assume there's a car starter involved. On my Viper, when you use the remote start, the front side marker lights and rear running lights come on and the dash lights come on in a partially dimmed mode. When you get in the car, you then insert and turn the key to the on position, then when you press on the brake pedal, the dash lights come on brighter/normal and your ready to drive away. I'm thinking the remote start function still thinks its in the initial remote start mode (the state its in after you command it to start, but before you get in and insert the key, turn it and press on the brake) with the partially dimmed dash lights illuminated.
Just a thought, I know all manufacturers can handle these things a bit differently.
Thanks so much for the replies. Yes i have a remote start but had the problem while i still had the alarm and had it taken off thinking it would fix the problem. It is no longer installled in my vehicle. The function of my Autopage alarm was very similar to ur viper but the lights that come on now werent the ones the used to come one before . Its the oil , brake , and a couple of others. EDIT Also i have no capacitor but had had all stereo and aftermarket electronics disconnected to try and diagnose the problem with a couple of shops and even neighborhood mechanics with no clue in wats going on.
Do you have an auxiliary capacitor for your subwoofers?
alotakoon
12-07-08 06:32 PM
