installing megans
Old 06-01-09, 10:05 PM
V.I.P LS4
V.I.P LS4's Avatar
Smile installing megans
i just put in the rears on my 95 ls400 , quick question when inserting the strut from the top does it matter what direction the **** is facing, if i did not adjust nything from the box, there is no indicators saying which way to face the struts does it matter ?
Old 06-01-09, 10:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
when inserting the WHAT from the top?
if you're talking about the adjustment **** for the dampening then No, it doesnt matter what orientation you put it in.
Old 06-01-09, 10:20 PM
LiCelsior
Retired
LiCelsior's Avatar
lol...just have the mount on the bottom line up parallel with the mount on the body.....should go in smoothly unless u messed with something.
Old 06-02-09, 12:11 AM
PureDrifter
BahHumBug
if you're asking about orienting the top and bottom mounts, then the easiest way is to just loosen one of the collars at the bottom to let you turn the lower mount. Lexus Repair manual tells you to have the llower perch perpendicular to one of the 3 mounting holes, ,but without a picture that's kind of hard to explain.
Old 06-02-09, 05:13 AM
Schnitz
Schnitz's Avatar
I'm surprised with all the Megans going in noone has posted a DIY.
Old 06-02-09, 08:26 AM
LiCelsior
Retired
LiCelsior's Avatar
its pretty straight forward, no need for a pic DIY.
Old 06-02-09, 08:31 AM
PureDrifter
BahHumBug
yeah, if you can't do springs/struts you don't really need to be installing the coilovers anyways.
for the front you can follow LexLS' basic guide. rears are damn easy as well, no need to remove driveshafts or anything else.
Old 06-02-09, 08:39 AM
LiCelsior
Retired
LiCelsior's Avatar
yep +1 to what PD said...coilovers are SOOOO much easier to install since u dont need to compress anything and plus their shorter than the stock ones (at first) so its easier to install since u can just jack the bottom mount in place.
Old 06-03-09, 08:22 AM
V.I.P LS4
V.I.P LS4's Avatar
its all good i know how to install everything went well, looks great it was just a general question because this was the first set of coilovers i put in.
hc1001
01-11-17 09:44 AM
ebnub
09-10-10 06:35 AM
Ariyanna
29
03-06-08 06:25 PM
rawdil49
Performance & Maintenance
01-24-08 01:35 PM
mrekid
RX - 1st Gen (1999-2003)
11-20-06 10:48 AM
Quick Reply: installing megans
