Hood Dampers Question
Old 04-19-09, 09:15 AM
KrapWerdna
KrapWerdna's Avatar
Default Hood Dampers Question
i got a question.
my friend has a 1996 LS400 and needs new hood dampers/hood lifts.
does anyone know the part # for it? i checked sewell but couldnt find the part.
thanks
andrew
Old 04-19-09, 09:49 AM
JAndersson
JAndersson's Avatar
The part nr for hood lifters should be 53440-59025. For some reason can't I post the link to the site with the information or even name it in the post. But if you are interested can I pm you the link
Old 04-19-09, 10:22 AM
mark98ls40
mark98ls40's Avatar
I just replaced my 98LS with mighty-lifts from Autozone & they work well & about $28 each.
Old 04-19-09, 11:47 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
just buy ebay ones. the OEM are ridiculously expensive and a lot of people using the mighty lift have bent their hoods because they're too strong.
Old 04-19-09, 07:10 PM
AzHotLS
AzHotLS's Avatar
I noticed that too on my 90 (I would say bowed, not bent though) but not on the 95. KW, I think your friend would be okay with the AutoZone ones on your 96.
https://www.clublexus.com/forums/ls4...od-struts.html
Old 04-20-09, 07:28 AM
KrapWerdna
KrapWerdna's Avatar
JAndersson - Sent you a PM
mark98ls460, PureDrifter, AzHotLS - i'll look into those. thanks
Old 04-20-09, 08:35 AM
Jitters
Jitters's Avatar
Good to know. The last set I bought from the dealer was somewhere in the neighborhood of $135 bucks a piece...Unfortunately, I had to replace all 4 struts.
Jitters
Old 04-20-09, 11:22 AM
mark98ls40
mark98ls40's Avatar
Maybe first gen LS hoods are lighter but my 98 hood weighs a ton so no bowing issues.
Old 04-20-09, 04:47 PM
AzHotLS
AzHotLS's Avatar
Four???? The hood only takes two! Did you do the trunk also?
If so, what year? I'd like to replace my trunk struts, but haven't found a supplier for them (other than stealer). There is another thread where trunk struts was mentioned but nothing posted yet saying where to get them.
Old 04-20-09, 07:37 PM
oofer
oofer's Avatar
Wink My 95 also needs new hood supports/shocks
Would you know what I should look for on ebay (part#, where on ebay ?) you seem to have done this before.
Thanks .
Oofer 95 LS, Montreal, Canada
jdanielca
03-09-19 12:35 PM
Sarathzzz
10-02-17 10:36 PM
airtraffic
SC- 1st Gen (1992-2000)
06-25-11 10:47 AM
xirforever
17
11-14-05 08:39 PM
Quick Reply: Hood Dampers Question
