1UZ-FE - 4.0L vs. 4.7L Swap
Old 02-27-09, 02:43 PM
Rocan
Rocan's Avatar
i dont think the 2UZ trany can be used with the 1UZ motor...
why not just take the motor and tranny out of a junker and drop them in?
Old 02-27-09, 03:46 PM
RandomHero
RandomHero's Avatar
Ok, but will a 1UZ tranny fit on a 2UZ motor?
I would take the motor out of a junker once I find out if it's worth doing. If I don't need the tranny from the 2UZ motor (if the 1UZ bolts up to the 2UZ just fine), then I'm not going to waste any coin. If it's too much hassle then I'll think of an alternate motor to use. No biggy.
Just trying to get some particulars.
Old 02-27-09, 03:48 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
i wouldnt do a 2uz swap if you plan on keeping everything stock. will detail reasons later, but im posting now in the hopes you won't commit yet.
Old 02-27-09, 05:47 PM
Rocan
Rocan's Avatar
woops, typed it wrong, meant the 1 UZ tranny on the 2UZ engine
Old 10-31-14, 10:33 AM
I'mStock
I'mStock's Avatar
Thread resurrection!!!!
I've been all over the internet and I can't find anything solid. It seems like all of the 2UZ swap into revolves around swapping rods, pistons and heads, which I'm not interested in.
I recently purchased a '98 with a bad motor and while I haven't opened it up to see just how bad it is yet I do know that if I end up having to replace the motor entirely that a 2UZ is going to be WAAAAAAY easier (and cheaper) to source locally.
I understand the mounts are different and would require custom fabrication (which I can handle) but I can't find ANYTHING regarding a 1UZ tranny bolting up to a 2UZ (i suspect it will...) or if a 2UZ will even fit, dimensionally, in the LS' bay...
Anyone?
Old 10-31-14, 11:36 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
like any motor swap with a bigger engine, this will require major work. you have not found anything solid bc it has not been done before, afaik! be the first!
dimensionally it should fit, but you will have to run custom headers. it is unknown still about the 1UZ transmission bolting up. wiring will be a nightmare. if you really want to tackle something like this, why not just go full on LSx! that motor is much easier to source and swap in with the plethora of knowledge out there now.
Old 10-31-14, 11:59 AM
Sc0pe
Sc0pe's Avatar
2UZ + CD009 manual?
Old 10-31-14, 01:55 PM
I'mStock
I'mStock's Avatar
I can't imagine the 1UZ trans wouldn't bolt up to the 2UZ but you're right, it's still an unknown. My co-worker is 1UZ swapping his '93 truck and his W58 adapter kit just arrived, I might order a 2UZ bellhousing and see what's what... I love a good LSX but I work at Toyota (parts) so the idea of keeping it all the same "brand" is super alluring, plus our master technician is down to tackle the wiring so that's a huge plus.
Old 10-31-14, 03:23 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
1uz swaps in anything haha. it's still an ECU controlled motor, but much easier to wire being OBD1.
i understand your wanting to stay toyota. i suppose the 2uz trans will not fit due to being 4wd? only one way to find out is to get the 2uz block, take measurements, and see if the bellhousing of the 1uz trans comes close.
Old 10-31-14, 03:51 PM
I'mStock
I'mStock's Avatar
I dream of a 1UZ Corolla track car to complete the Toyota trifecta in the garage but I refuse to pay the drift tax.
Once we begin tear down of the LS Im sure all these questions will be answered, I really started looking into this as a "simple" solution if my 1UZ does turn out to be complete garbage but the more I think about it the more I'm into it....
Ostslexus
06-13-16 08:45 AM
Durvelle27
Performance & Maintenance
04-18-15 07:52 AM
Anti-Venom
06-25-11 11:35 AM
SupraDupra
06-19-08 04:15 PM
sonoramike
11-01-07 07:20 AM
Quick Reply: 1UZ-FE - 4.0L vs. 4.7L Swap
