99 LS Steering wheel groand when telescoping down
Old 02-16-09, 01:25 PM
bradland
bradland's Avatar
Default 99 LS Steering wheel groand when telescoping down
After driving my first LS (91) for 3 months short of an entire decade, I am happy to have my second. A gorgeous Blk Onyx 99. I was hearing a groan of sorts when I removed the key and the steering wheel telescoped down (away). After removing the plastic cover I discovered the design has been upgraded from 1st Gen to a far superior design!! Thank you! I simply applied a little white lithium grease to the shaft above the collar which holds it and moved the unit in and out several times to distribute the grease. Now it is very quiet and hopefully no added strain on the tele motor. Just wanted to share the simplicity of this quick and easy fix.
Old 02-16-09, 02:12 PM
Kansas
Kansas's Avatar
I've posted it before but here is the TSIB for the steering wheel groan problem in the 99-00 LS400.
Old 02-18-09, 05:49 AM
cartechpr
cartechpr's Avatar
that is a remove and replace thing... is there anyway to fix it? Mine doesn't want to come down full way a lot of the times and I have to wait a while for it to be able to move.
Old 02-18-09, 08:31 AM
Kansas
Kansas's Avatar
There have been past threads on fixing the tilt on an older LS400 by putting a washer or something else behind a plastic sprocket. I think you can find the threads if you do a search. There is even a very nice video on youtube on fixing the tilt on an older LS400 -- search youtube for LS400 and I'm sure you will find it.
I don't know if the fix would work on your 99 LS.
cmotomn
25
07-03-16 05:27 PM
BOOGEYMAN4
08-04-11 01:14 PM
ctls
05-18-11 09:04 AM
dleadlexus
01-12-10 10:52 PM
jjsoni1
05-21-09 09:43 AM
Quick Reply: 99 LS Steering wheel groand when telescoping down
