she wont start!!!!plz help
Old 02-09-09, 08:03 PM
gdave
gdave's Avatar
Default she wont start!!!!plz help
so two days ago i had a blow out wile the ls was parked i front of my house..weird..pushed the fender out a little..so i got the tire fixed ok, im at the laundromat with my girl tonight we're all done hop back in and she sounds like she wants to crank over and start but nothing.. battery is good,lights and radio work..have gas too.im stumped its sitting in the laundromat parking lot as i type this...im out of ideas...any and all help would be good.
thanks,gdave
Old 02-10-09, 05:57 AM
Bradster
Bradster's Avatar
clean and tight battery connection...weak alternator perhaps..
Old 02-10-09, 06:25 AM
LiCelsior
Retired
LiCelsior's Avatar
check all fuses to make sure their all good and like bradster said, check your terminal connections.
Old 02-10-09, 07:53 AM
python
python's Avatar
huh? check ur connections on the battery? lol...i would think its a fuel or spark issue, unless u have a blown efi fuse or something but if it cranks over it has nothing to do with the alternator or battery
Old 02-10-09, 10:58 AM
qewani1
qewani1's Avatar
search in forums.
Old 02-10-09, 11:10 AM
gdave
gdave's Avatar
connections were cleaned and still nothing,i have optima yellow top and i replaced the alternator last june its at my mechanic im guessing its def a fuel or spark issue...the plugs r pretty old i gotta say.....waiting on the call from my mechanic
Old 02-10-09, 12:59 PM
cation
cation's Avatar
This may be caused by the mysterious trunk wire harness issue.
It's been reported on the forums that sometimes the wire harness attached to your driver's side trunk hinge fails and causes a ground fault. Try unwrapping the wire loom to see if there are any broken or frayed wires in there grounding out. It's something easy to do while you are in a parking lot without a full set of tools.
Old 02-10-09, 07:03 PM
KCLEX
KCLEX's Avatar
Pull one of the coil wires out just enough to see if its getting spark, at the coil. Do not hold the wire just pull it out a little and have someone turn it over while you are looking at it. I do not think it would be the plug to just not start all at once. If you have spark, I would look at the fuel pump I hear they are notorious for just quitting. Good Luck
Old 02-11-09, 07:25 AM
qewani1
qewani1's Avatar
check this post here photos of DIYs, have a fun
https://www.clublexus.com/forums/gs-...roblems-2.html
Old 02-11-09, 09:38 AM
atoyot
atoyot's Avatar
so it turns over and over, but will not fire?
That happend to me just last week on my 00' LS. While the girlfriend is cranking the car, smell the exhaust for raw gas.
I popped the trunk and looked at the wires running down the trunk hinge, driver's side. Had a little worn spot, so i wiggled them a bit and it started right up.
Give that a shot.
Old 02-11-09, 11:06 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
you should probably fix those wires.
Old 02-11-09, 11:27 AM
qewani1
qewani1's Avatar
Give that a shot.
OMG just now am seeing this post, I hope that is not same issue in my car!
because i ended with replacing the whole starter (392 $ labor + OEM starter assy).
Old 02-11-09, 12:41 PM
atoyot
atoyot's Avatar
I know. I have been lazy lately. At least if it does it again i know where to go.
Old 02-11-09, 12:43 PM
atoyot
atoyot's Avatar
i couldn't tell in your first post if you were saying the lights and stuff worked but it wouldn't turn over, or it would turn over just would not fire?
Old 02-11-09, 02:05 PM
qewani1
qewani1's Avatar
my LS was just giving loud click sound something like "tak tak" on each turn of key to start...and was not even crank,,sometimes it crank without starting...actually i was pressing gas pedal sometimes so after that turning the key to start ..then it cranks and i press direct on more gas pedal to make the engine start....the amazing thing is that all this started after my nasty connection of ground wire for DRL .
it started after ten days of this nasty connection of wires see picture below...
after searching in google i found that bad ground wire may affect on starter job, so i had disconnected this nasty connections and taped end of each wire....so after three days my car was ok...it was starting again from first click...after that i again made my nasty connection as shown above ..and everything was ok tell after ten days again starting problem came back..so i had posted this thread to take ideas & opinions from members here in forums..
https://www.clublexus.com/forums/ls4...wires-how.html
but no one has told me that these things are related! untill i saw your post !
Today i got starter replacement with new one. Hope that everything will be ok!
YoungNas
16
12-10-18 04:13 AM
cee25
07-31-14 09:38 AM
Jblkstr
03-24-13 08:35 PM
LudeNsoL
11-17-10 06:59 PM
melissac
07-19-10 03:15 PM
Quick Reply: she wont start!!!!plz help
