Nagisa Auto Front Camber Blocks... Any Good?
Old 10-27-08, 12:03 PM
robz_11
robz_11's Avatar
Default Nagisa Auto Front Camber Blocks... Any Good?
wattup peeps... just wondering if the Nagisa auto front camber blocks for a UCF20 really adds 2-3 more degrees in angle.... does anyone have pics of them installed on their ride??? Let me know peeps.. Thanks..
Old 10-27-08, 04:48 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
link ?
Old 10-27-08, 04:54 PM
MELLO*SOS
MELLO*SOS's Avatar
Robz their page says they add 4-5... But I've never used them so I couldn't verify that.
PD I assume he means these ones, 2/3rds the way down the page:
"Span of adjustable range of front camber narrow the offset being able to point to the lower ball joint section, by the fact that you install, it actualizes the negative camber of +4 - 5 degrees.
Because thickness is 20mm, stroke width is raised.
(The low down of 20mm OK)"
Old 10-27-08, 06:24 PM
PureDrifter
BahHumBug
Forum Moderator
that's nothing more than a Roll Center Adapter.
YouZealand sold them as part of their SS Kit for a while for ~$500.
iirc AutoFashion is coming out with a set (front/rear) for <$400 soon, sometime round december i was told.
Old 10-27-08, 06:27 PM
robz_11
robz_11's Avatar
thanks for the replies... im trying to get some negative camber to tuck some 19s thats why. any other ideas to be able to do that???
Old 10-27-08, 08:20 PM
PureDrifter
BahHumBug
Forum Moderator
....RCA's add POSITIVE camber. unless those are fully adjustable which i doubt.
what offset are you running that makes you think you need to add neg. camber on a lowered car...?
Spamboi
06-18-15 08:39 AM
Gville350
Suspension and Brakes
27
01-31-14 07:09 PM
JPRESTIGE
08-15-12 07:39 PM
luigy
07-31-11 01:48 PM
twenty
05-30-11 12:14 PM
Quick Reply: Nagisa Auto Front Camber Blocks... Any Good?
