stereo system 91 LS400
Old 09-05-08, 04:24 PM
tj_lee1
tj_lee1's Avatar
Default stereo system 91 LS400
Okay I just bought and installed 2 12 kickers subwoofers. The problem is when i turn up the volume the stock woofer sounds like its going to explode. How would I fix this?
Old 09-05-08, 05:06 PM
Iansaltes
Iansaltes's Avatar
It's either blown, or you need to set up your LPF on your deck so that your stock sub isnt trying so hard to keep up with your other subs.. or simply remove the sub. there is no "fix"..unless you put another in its place (8") with more resistance, but you dont need that since you have already have two more.
you should keep waiting for a more qualified answer, though. A lot of guys here know way more about this kind of stuff than I do.
Old 09-05-08, 08:52 PM
Celsior400
Celsior400's Avatar
remove the 8" woofer if you plan on running 2 12's it willget more sound from those subs.
Old 09-06-08, 04:33 PM
tj_lee1
tj_lee1's Avatar
hrmm How do i remove it.
Old 09-06-08, 04:38 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
take the rear seats out, remove the parcel shelf, and unbolt it.
Old 09-06-08, 07:57 PM
LiCelsior
Retired
LiCelsior's Avatar
http://www.lexls.com/tutorials/light...stoplight.html
Old 09-08-08, 01:55 PM
unstephenk
unstephenk's Avatar
What size sub can I fit in its place?
Jtc016
03-19-17 01:22 PM
1996LS400
27
02-25-08 02:29 PM
vsynergy
10-13-05 06:27 AM
50loser
02-26-05 05:23 AM
studaddy
02-06-03 08:12 AM
Quick Reply: stereo system 91 LS400
