94 LS400 Won't Start? Is it my spark plugs?
Old 08-05-08, 12:28 PM
Liguid
Liguid's Avatar
Default 94 LS400 Won't Start? Is it my spark plugs?
So last Monday i decided to seafoam my car, and everything went smoothly. My car started fine and i didn't notice a big change except for a slight increase in mpg.
Well my car has been working fine till last night. I drove out to eat dinner with a few friends, then drove to their place to hang out. I came out 3 hours later to find out my car just won't start. When i turn the key in the ignition it sounds like it normally does, except it just won't start. Everything sounds fine but for some reason it won't start. I'm pretty much a newbie when it comes to auto mechanics so im not sure what exactly is the problem. I checked the fuses and everything looks fine. I tried unplugging my battery and that didn't work. Check all the cables visible to make sure they were not loose. So i was curious if it might have to do with my spark plugs. I found a diy guide from lexls.com on how to replace the spark plugs, but wasn't sure if it was. If it ain't my spark plugs, i guess i'll have to go get my car diagnosed. One of my friends said it could be my alternator but i have no idea. I just wanted a second opinion before i actually go do a diagnostic.
I just bought this car about back in may, and the owner didn't say anything about changing the spark plugs. so as for maintenance im not sure when it was last checked.
I MIGHT be able to provide a video in an hour if my buddy has time to bring his camcorder.
Any help would be appreciated.
Old 08-05-08, 01:16 PM
atoyot
atoyot's Avatar
when you say it wont start, do you mean the starter is turning, everything is cranking just not starting? Or do you mean your starter won't turn over?
Can you smell gas?
You said you checked fuses, have you checked the EFI fuse or relay?
Old 08-05-08, 02:27 PM
python
python's Avatar
have someone turn the car over and u go in the rear and see if u smell raw fuel coming from the exhaust
Old 08-05-08, 03:38 PM
lexie
lexie's Avatar
Nothing to do with spark plugs!
I have exactly the same problem last week; towed the car to dealer, they said ECU no good.
note: my engine would keep running rough after start if I floor it, otherwise it stalled right away after start.
Old 08-05-08, 06:49 PM
Liguid
Liguid's Avatar
Can you smell gas?
Exactly what i mean, everything is turning and its cranking but its a no go. I'll double check the EFI fuse and where exactly is the relay?
i'll have someone help me with this as soon as my house mate comes back from work.
any idea how i would check or replace my ECU without bringing my car to a shop?
Old 08-05-08, 07:01 PM
Liguid
Liguid's Avatar
Ok i think i may have found the problem, i found out the EFI fuse blew again. i replaced it this morning. I just replaced it again and tried to start the car but again it didn't start. So i went to check the EFI fuse and i found out it blew again! any idea? or is it cause i got cheap fuses?
Old 08-05-08, 11:01 PM
Liguid
Liguid's Avatar
update, i put in one more fuse and it blew right when i turned the ignition key to start the engine. any idea what it might be?
Old 08-05-08, 11:45 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check teh fuse pump perhaps...
or the trunk hinge wiring harness (see lexls.com lighting section on strange dash problem.)
Old 08-06-08, 12:03 AM
Liguid
Liguid's Avatar
im not sure how this might help me start my car? is it cause it may be the cause of my EFI fuse blowing?
Old 08-06-08, 06:37 AM
JBrewster
JBrewster's Avatar
sounds like there is a short that keeps popping the fuse.
Old 08-06-08, 07:58 AM
atoyot
atoyot's Avatar
i think what puredrifter was getting at is that this sounds like a wiring issue. Something is causing your EFI fuse to blow. Either a bad ground or a wire has rubbed through the insulation allowing a short. I do not know the wiring of your car but perhaps the EFI wiring is somehow tied into the trunk hinge wiring harness. Maybe it has rubbed thru there.
I would start tracking wires now.
Old 08-06-08, 09:25 AM
PureDrifter
BahHumBug
go check.
the trunk hinge wiring harness problem has caused many weird electrical gremlins....
sam6918
Maintenance
11-16-13 02:35 PM
Rolando
04-22-10 11:05 AM
Vortes
Performance & Maintenance
08-20-08 09:28 PM
porshapowe
02-11-07 05:14 PM
lsflame
11-13-06 07:28 PM
Quick Reply: 94 LS400 Won't Start? Is it my spark plugs?
