Project Update, suspension, wheels and tires
Old 08-03-08, 01:51 PM
93lexES300
93lexES300's Avatar
Default Project Update, suspension, wheels and tires
Just wanted to post up some pics of my car as it comes along. Some of you may remember my car on Tanabes and comparing different size tires after the drop.
I have since installed KYB struts and H&R springs as the tanabes were too soft for me. Here are side by side pics comparing the springs, stock on left, tanabes in center and H&R on right.
Front:
Rear:
Here is the car on the kyb's and h&R's with SC430 wheels and 245/40/18 runflats. Also tinted the tail lights.
Old 08-03-08, 02:55 PM
rgindallas
rgindallas's Avatar
Looks GREAT!!
How is the comfort/ride portion changed?
How is the cornering portion changed?
RG
Old 08-03-08, 08:08 PM
LiCelsior
Retired
LiCelsior's Avatar
very nice, looks very clean with the subtle drop.
Old 08-03-08, 09:21 PM
anotherLS
anotherLS's Avatar
if you need another run-flat i got one
Old 08-03-08, 10:40 PM
Flat Four
Flat Four's Avatar
Very clean. That is one straight 1st gen!
Old 08-04-08, 07:37 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Lookin' good!
Old 08-04-08, 07:46 PM
ryanSC300lover
ryanSC300lover's Avatar
Needs way more drop
Old 08-06-08, 11:58 PM
93lexES300
93lexES300's Avatar
Thanks to all the feedback.
The ride is pretty comfy with the H&R's, almost as comfy as the tnanbes, but the car is much more solid around corners. I preffer the H&R's hands down, even though the drop is not as much as the tanabes. Going for function over looks on this one, so no more of a drop for me than the H&R's have already provided. I will get a slightly thicker tire when the current ones wear out, which will close the small gap between tire and fender.
Next plan is to remove the resonators and replace with magnaflow straight through mufflers and just pipe from that back. I want the V8 sound.
Will be upgrading to braked from the 93ish LS400 as the rotors are about an inch bigger in diameter, which may not seem like much, but that gives an over all 15 to 20% surface area, which will be significant in stopping power as well as aid in cooling, especially with slotted cryo rotors.
Will not be doing the SupraTT brake upgrade as mine is a 91 and it's too involved for my intended use at this time, just in case anyone was going to raise that question.
Thanks again for all your feedback and input....
Old 08-07-08, 12:31 AM
I8ABMR
I8ABMR's Avatar
man the car looks so much better now. you did a great job . enjoy.
Old 08-07-08, 06:04 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
the hell are you talking about, TT calipers and rotors are BOLT ON.
its the 2LS conversion that you have to either get some RCAs made or shave a bolt.
Old 08-07-08, 07:45 AM
python
python's Avatar
dont u have to change the backing plate if u get larger rotors?
Old 08-07-08, 10:18 AM
Suneet
Suneet's Avatar
I don't think you need to change the backing plate, you just need to cut the dust shield/guard.
Detailed writeup:
http://www.lextreme.com/lsbrake.html
Car is looking good! I feel you on the function over form, I made most of my mod choices around the same issue. I miss my LS
Old 08-07-08, 02:36 PM
93lexES300
93lexES300's Avatar
Ok, I mean the 2LS rotors, the Supra TT's are a little pricier. Not sure if the SC430 wheels will clear the SupraTT calipers, as I've read they won't clear the 2LS calipers.
Old 08-07-08, 03:16 PM
PureDrifter
BahHumBug
sc430 wheels, without spacers, will not clear ANY big brake kits.
Old 08-07-08, 04:28 PM
93lexES300
93lexES300's Avatar
But they should clear the 93 LS calipers.
Quick Reply: Project Update, suspension, wheels and tires
