93 ls400 question
93 ls400 question
i just bought a ls400 and the foglights dont work, would you guys mite know what the problem is? allso the radio and the climate control lights go off when i turn on the headlights......
thanks for the help
thanks for the help
I think I have the same problem, I don't know where the relay is...
Never mind, I found it. Dumb me.
https://www.clublexus.com/forums/sho...t+relay&page=2
When my previous LS400 (1990) was about 8-10 years old, the foglights started working erratically. If I remember correctly the fix listed on the repair invoice was "cleaned corrosion at fuse block". The repair shop would clean off the corrosion and the foglights would work fine for another year or two before the corrosion had to be cleaned off again. I never asked where the corroded fuse block was located but the current owner told me a while back that it was under the dash and getting so bad that the entire fuse block was going to have to be replaced.
I should have grabbed a ton of relays from a junkyard when I had the chance...
ThomasGS4
43
04-25-12 02:22 PM
garyjohan
04-12-11 12:48 AM
