Transmission fluid, draining & flushing (The Mother thread)
#181
Lexus trans service
I serviced the trans in my 00 LX470 with 182K on it and it shifted much better. I think if it fails after a service, it was almost ready to fail anyway. I disconnect one of the cooler lines (the line with fluid going into the radiator), put it in a bucket, crank the engine, and let it pump the dirty fluid out. Meanwhile, you can begin pouring fresh T4 fluid in. You may have to stop the engine along the way to catch up with fluid pour, but this gets most of the dirty fluid out. Pulling the pan and cleaning it is a good idea too, but maybe after you get the fluid cleaned up. Make sure you have 8-10 quarts of T4 on hand.
#183
That's the process I would take. First, pull the pan, clean, and drain. Use the recommended sealant when putting the pan back in place, not a gasket! Then, at each oil change, pull the plug and replace the Toyota T-IV (about 2 quarts) of fluid until it runs good and red.
#185
Lexls + these forums say to use a gasket. It seems easier and alot less messy. What is the reason for having to use sealer instead of gasket?
#186
#189
transmission fluid chang
I saw your problem I would find a good tranmission shop and have them look at the trans, first thing is to pull the pan to see of there is any metal parts in the pan from gear wear or clutch plate wear. If not you can put the pan back and put in the amount of oil that the pans holds. find out how many quarts the pan hold when you drain the oil from the drain plug in the trans pan I would drain the trans refill it again drive about 10 minutes drain it again and again until you have drained it about 12 quarts this will give your lexus fresh transmission fluid. Then every 10-15,000 miles just drain the pan from the drain plug and put back the same amout the trans should go a long way. I use mobil one synthetic trans fluid on my 91 LS400 and no ill effects in fact it shifts real well and it has 188,000 miles on it now. you can buy the Toyota type 4 used in the Lexus transmission at Toyota and save money if this is the way you choose to go.
#190
I brought 12 quarts or Type IV and drained the pan, took it off and cleaned it, re-set magnets and sealed it back on. Then over a few days I drained and re filled it. Took three turns and now the fluid is clear and runs soooo smooth my friend asked me when I was on the highway if I had it in drive because they didn't feel the shifts! It is a little slower but I think safer and quite effective.
#191
I like cork gaskets personally, and thats what I bought for my pan.
You can do the drain, remove, drain, remove situation, because there's roughly about 1 quart of old fluid left in the torque convertor if you just do a single drain.
Maybe do what Ewen said and drain it several times. That can get expensive, but way cheaper than buying a new transmission and install...ouch...
#193
Transmission oil--Toyota Type II?
I understand that CL members always suggest to use the Toyota Type IV transimission oil and I bought 11 quarts of them. But my 1997 LS400 owner's manual said that Toyota transmission oil Type II should be used. Which oil should I use?
Please advise.
Thanks.
Please advise.
Thanks.
