rev up to 2000rpm then drop
Hi everyone, i just notice that my car wont allow me to rev the engine more then 2000rpm when it stands still. meaning, when i step on gas pedal and shifter is in P, the engine rev up to 2000rpms and automatically drops back to 650rpm even if my foot is still on pedal depressed. if i try again, engine rev up to 2000 and drops back to idle
If the car is in action (shifter in D) engine easily reaches to 3000 rpm before shifting to another gear when i floor
is that normal for all 1990 LS400? (95k miles on clock)
thats weriddd. my 1995 LS400 lets me go to full redline in park. i believe there is somethin wrong there. In drive my car will shift at 3k rpm if im just cruisin and when i mash it full redline. if the owner before you drove slow that might be the reason. i would unplug the battery for 10sec -20sec. put it back on so it can reset the ecm.
http://www.lexls.com/tutorials/EFI/tps.html
there the TPS readjusting
i would do the battery unplugging first and see what happens . do the easiest things first before the hardest :]
thanks guys, i am still confused why tps (throttle position sensor) may be the cause as it is still working fine when the car is running (reach to 3000rpm before shifting to next gear)
I8ABMR
IS F (2008-2014)
15
05-12-15 08:09 PM
vintagekar
01-29-13 07:20 PM
PBLexusES
06-08-07 10:30 AM
