Vibration at 1100 rpm
Old 01-22-08, 04:48 PM
dashan
dashan's Avatar
Default Vibration at 1100 rpm
I replaced the tranny mount in my 96 LS400 recently. But I still get the vibration at 1100 rpm while driving.
I did the following tests today.
1, I parked the car and the gear is in “Park” and revolved the engine to 1100 rpm, no vibration.
2. I parked the car and the gear is in “N”, engine at 1100 rpm, no vibration.
3. The car was parked and no moving by pressing the brake pedal, the gear is in “D” or in “3”, revolved the engine to 1100 rpm, and the vibration was reproduced.
I am thinking the vibration is caused by bad engine mounts. What else could cause the problem?
Thanks
Old 01-22-08, 05:29 PM
LiCelsior
Retired
LiCelsior's Avatar
um...when u put it in D and holding the brake and accelerator....ur going to get some vibration and eventually a burnout lol.
Old 01-22-08, 05:42 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
yea, the engine is going to do that, you're putting load on the drivetrain, and heating the hell out of the transmission.
never driven an automatic before
Old 01-22-08, 05:47 PM
TMaxxTim
TMaxxTim's Avatar
All you can do is replace all the mounts, and 90% of the time those will be the source of all your vibration problems. If replacing the mounts doesn't solve the problem, there is something more serious that needs to be looked at.
Also, is your vibration at any speed inparticular or does it occur at 1100rpm nomatter what speed your at. Do you notice any other vibrations that appear at other speeds (highway)?
Old 01-22-08, 06:08 PM
dashan
dashan's Avatar
In the above tests, the car didn't vibrate at 1000, 1200, 2000, or any other rpms.
Old 01-22-08, 06:13 PM
dashan
dashan's Avatar
No, the car only vibrated at 1100 rpm, no related to speedanys. No vibration on highway.
Old 01-22-08, 07:24 PM
sonyman
sonyman's Avatar
Replace your engine mounts. 1100 RPM must have a resonance frequency associated with it.
Nickvt90
11-21-18 10:24 AM
Ls400dan
11-03-16 11:02 PM
cashvegas
15
03-12-16 08:47 AM
yeskay
06-27-10 09:48 PM
Technics
Performance & Maintenance
10-11-04 05:19 PM
Quick Reply: Vibration at 1100 rpm
