How to program the garage opener
Old 10-29-07, 05:58 AM
tbilisi79
tbilisi79's Avatar
Default How to program the garage opener
guys how do I program the factory garage opener on my 98 ls?
Old 10-29-07, 06:30 AM
black_LS
black_LS's Avatar
Don't remember off the top of my head.. but it's in the manual.
Old 10-29-07, 08:30 AM
tbilisi79
tbilisi79's Avatar
would not ask if I had a manual!!!
phil0909 (05-11-21)
Old 10-29-07, 09:03 AM
LiCelsior
Retired
LiCelsior's Avatar
u can order a new owners manual from the lexus website, u gonna need ur vin number and stuff.
Old 10-29-07, 09:14 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
not sure but iirc its as follows (written from memory, dont bug me if its wrong/doesnt work)
hold down the center button until the light starts to blink, then hold down the button you want to program while at the same time pressing the button on your existing garage door opener (hold itup next to the one in the car at this point) and hold BOTH the button u want programmed on the car and ur garage door opener until the light in the car stops blinking/blinks faster (one of the two).
enjoy.
Old 10-29-07, 01:01 PM
98LS
98LS's Avatar
I think Pure Drifter's right about programming. I also think you may have to disable the rolling codes feature on your garage door opener if it is so equipped.
Old 10-29-07, 02:38 PM
sonyman
sonyman's Avatar
Here's how off the top of my head:
First, hold down buttons 1 and 3 until it starts to blink slowly, then rapidly in order to clear out anything that may be stored in memory.
Disconnect power to the garage door opener. I recommend just opening the circuit at the breaker box. Then, take an already programmed garage door remote and hold it 2-3 inches away from the homelink. Hold down the the button on the homelink you want to program and the programmed button on the remote at the same time for 30 seconds or until the light blinks at a different rate on the homelink. I believe it will blink faster when its programmed. Reconnect power, or close the circuit.
Now, if you don't have a rolling code garage door opener, you're good. If not, proceed.....
Go up to your garage door opener, and find the training button. You may have to remote the cover over the lights or a similar cover to access it. It should be marked. Press the button on the garage door opener. Now, within 30 seconds, go back to your car and press the programmed button on the homelink. The garage door should operate properly. If not, try the button again, and as a last resort, repeat this process in its entirety, including resetting the homelink.
Old 10-19-14, 04:55 PM
Jofosho
Jofosho's Avatar
Thank you! holding 1 and 3 erased my old memory. bushed the "learn" button on my garage door motor(actual garage door motor). then held my button in my car that i wanted to program and lights in garage flashed! easy as 1,2,3. thanks guys! 98 car with automatic garage door opener awesome!! haha
Old 10-20-14, 11:58 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
it all depends if you have a rolling-code garage door opener or a standard one. the OEM garage opener in the car is made by homelink, which the same across a whole range of cars not just the LS400!
http://www.geniedoor.com/homelink-ga...er-programming
Old 10-21-14, 08:38 AM
sha4000
sha4000's Avatar
I never even bothered to program mines I just used the remotes that came with the system.
Old 10-21-14, 09:30 AM
billydpowe
billydpowe's Avatar
well I programmed both of mine since both go into the garage and it is so easy...
I dont even know what timmy was talking about .mine works..
Old 10-21-14, 10:10 AM
AZLexTech
AZLexTech's Avatar
What he's talking about is different levels of security in certain garage door motors. When programming to homelink, you either do it in a one step process or a two step process. A rolling code motor requires the second step, which is pressing the "smart/learn" button on the motor, then cycling the homelink button in the car.
Old 10-21-14, 01:16 PM
billydpowe
billydpowe's Avatar
thanks AZ, mine is so old it is one step...... every thing I got is old
Peredhil
05-04-18 07:17 AM
01GS430
04-13-10 01:13 AM
deadeyed
12-30-08 05:44 PM
FRSTLX
ES - 5th Gen (2007-2012)
03-20-08 12:33 AM
fireballs gs400
09-21-06 09:21 PM
Quick Reply: How to program the garage opener
