Another newbe question
Old 10-08-07, 06:47 PM
Atl
Atl's Avatar
Default Another newbe question
Hello all,
Just wondering, on a 1999 LS if the timing belt breaks, does it cause engine damage with the or just leave you stranded? What really happens if the belt breaks ?? I'm being told it is going to cost me $1,100.00 to have it and the water pump replaced. And why would the water pump only last 90K miles?? Don't really understand this.
Thanks, David
Old 10-08-07, 06:56 PM
vredniykot
vredniykot's Avatar
it's called preventative maintenance
Old 10-08-07, 06:57 PM
LiCelsior
Retired
LiCelsior's Avatar
i forgot which motor but i remember reading that if the timing belt breaks then the whole motor is gone and it'll be a costly repair.
Old 10-08-07, 07:49 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
yea, 99 LS uses the interference motor so if the belt snaps u can kiss ~5grand+ (VVT-i motor+install) goodbye
1100 is about right for a dealership, a good independant could lower that a few bills.
Old 10-08-07, 11:11 PM
sbguyy
sbguyy's Avatar
Your being told WRONG! Pure Drifter is telling you the right infromation!! I have seen two timimg belts break under a 95,000 miles! on 1998-2000 LS
Good luck,if you want to take the chance?
Old 10-09-07, 12:08 AM
CptnTonus
CptnTonus's Avatar
If the belt breaks, the pistons will hit the valves, and the valves will bend. Sometimes all you need to do is swap the head(s), and other times the pistons/valves hit so hard that the pistons need to be replaced as well. In general, it's not worth risking it. Just change the belt at the recommended factory service interval and you won't have to worry about it.
PureDrifter
BahHumBug
who's wrong, the guy was asking IF it would break
Old 10-09-07, 06:16 AM
fst4dr91
fst4dr91's Avatar
if you timing belt breaks being a 32v interfearence motor
your motor will be fubar for sure
Old 10-09-07, 06:30 AM
steveski
steveski's Avatar
Hello all,
Thanks, David
Everybody is telling you good information bro. The engine is an interference motor and not changing is a gamble you shouldn't take since it will cost you dearly if it breaks. Lexus probably engineer the belt to last much longer but why take the chance. Mine is coming up to 200,000 miles and I will be changing mine again. I paid around $1,100 (Houston) and it included water pump, other front engine parts and spark plugs.
As for the water pump it will last much longer. The mechanic is saying that he will have to take it off to get to the rest of the assembly - might as well change it rather than put it back on.
Old 10-09-07, 11:54 AM
19psi
19psi's Avatar
do it! change that timing belt and water pump. the water pump is fine and probably will be for a while but one day it will start leaking and then you'll be paying the same labor as you did for the timing belt job. so basically you'll be paying twice the labor if you don't get it all done at once. or you could drive up here and i'll do it for $500. i'm an ex-lexus tech.
Old 10-10-07, 07:40 AM
alsalih
alsalih's Avatar
sbguyy, you've seen two 98 LS's with belts breaking at under 100K miles, do you work at a dealership? That's the first I've heard of one breaking that early. Glad I got mine done!
Old 10-10-07, 08:19 AM
sbguyy
sbguyy's Avatar
No, I don't work at a stealerships! But I am very close to my indepentent shop! The car my son drives now( 99LS) was one of the broken belts I wrote about.It broke at 96,000 miles. The owners where going to send it to the junk yard. The car was perfect(except for the motor) I bought it for 1500 dollars. Now my son drives a great and safe care for an investment of 7000 dollars.
It is rare that the timing belt breaks that early!! But it does happen!!
Old 10-10-07, 10:58 AM
dashan
dashan's Avatar
Hi, 19 Psi,
Where are you in KY? I might drive my car to your place for the belt replacement. I am in Louisville.
Old 10-10-07, 11:49 AM
Lexkost
Lexkost's Avatar
Pull one of the top caps off and inspect the belt yourself, this is what I did and I went 130,000 plus on my car.
Old 10-13-07, 07:29 AM
19psi
19psi's Avatar
Originally Posted by dashan
Hi, 19 Psi,
i work in louisvlle, livein lagrange. i can hook you up on the parts too, i ge tthem at a discount.
Bjamin75
03-03-17 08:29 PM
GeeTee
02-21-11 08:06 PM
UpperCase
Performance & Maintenance
12
12-18-07 10:20 AM
ShaneC
06-29-06 12:51 AM
Quick Reply: Another newbe question
