Front Suspension Problems. Need advice
Old 10-01-07, 06:45 AM
tbilisi79
tbilisi79's Avatar
Default Front Suspension Problems. Need advice
Did some research, but want to make sure one more time.
When breaking and applying brakes, going over the bumps, I get clunking sounds from the front.. Its so bad that it hurts, is is the upper control arms or the strut arms.
I am getting the strut arms one way or another next week, but would love to get some input one way or another.
Thanks
Dave
Old 10-01-07, 10:22 AM
projman
projman's Avatar
Dave - I had this with my '98. It was the strut arm bushings. I replaced them myself and it made a huge difference. If you have them done, expect to pay at least $450.
Old 10-01-07, 06:42 PM
skperformance
skperformance's Avatar
It is actually called strut rods and they go all the time.
It can be done cheaper by buying replacement bushings only instead of the whole assembly.
Old 10-02-07, 01:12 PM
tbilisi79
tbilisi79's Avatar
Can i get bushings separate? I know Lexus doesnt have them. And the Rod with bushings is $127 , not that bad, I can install them myself.
What do you guys think
Old 10-02-07, 01:17 PM
Thermactor
Thermactor's Avatar
Old 10-02-07, 02:17 PM
tbilisi79
tbilisi79's Avatar
Part number? Where in Lexus or where?
Old 10-03-07, 01:10 PM
steveski
steveski's Avatar
Any Lexus parts I call Luis or Steve at Carson Toyota www.carsontoyota.com since they give me the best OEM pricing if the part is available.
Old 10-21-07, 07:40 AM
alufront
alufront's Avatar
where can i get these replacement bushings??
Old 10-21-07, 09:05 AM
LiCelsior
Retired
LiCelsior's Avatar
he posted right on top of u.
Old 10-21-07, 09:07 PM
akxx
akxx's Avatar
Keep in mind that replacing the strut rods may make more sense--sure bushings alone are cheaper, but when you consider the effort and possible extra expense of pressing in/out bushings, the entire strut rod may not be such a bad deal.
I think strut rods with new bushings can be had for $100.
Old 10-21-07, 09:51 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
ive done the math after presenting that same arguement and im about to order 2 sets of OEM bearings (both sides) and having them pressed in.
my local NAPA autoparts will press out/in my bushings for $10/each
Old 10-29-07, 02:18 PM
hazian23
hazian23's Avatar
I also have a problem with my 2000 LS. When ever I go over sharp bumps or potholes I hear a louder than normal clunk which sounds pretty bad. Is the Strut Rod all I need to change or should I look at changing other components. I'm running about 110k miles on it right now and I want to get alot more. Also is there an online parts dealer which I can order from?
Old 10-29-07, 04:18 PM
PureDrifter
BahHumBug
Forum Moderator
most likely strut rod.
call Luis at carson Toyota
1800-908-6968
9000revs
02-02-15 06:43 PM
PlotPoint
20
10-23-14 09:08 AM
JZCHAOS
09-27-13 06:03 PM
blazer84
Suspension and Brakes
03-18-12 07:56 PM
damon
10-05-05 11:53 PM
Quick Reply: Front Suspension Problems. Need advice
