Help, No spark
Old 07-19-07, 09:26 AM
kevinindy
kevinindy's Avatar
Exclamation Help, No spark
I need some ideas to fix my 1992 ls 400. I'm not getting any spark. Replaced the ignition coil and still nothing. Seems like no power to the coil. Checked every fuse. Any ideas would be appreciated.
Old 07-21-07, 07:00 PM
michael200
michael200's Avatar
Is the check engine light on? Would start by reading the engine codes.
Old 08-06-07, 08:23 PM
lwfalcon
lwfalcon's Avatar
Go to the fuse box under the hood. High temperature can cause the fuse contacts to corrode and develop a high resistance or even total loss of contact between the fuse and the the fuse socket.
I suggest you physically remove each fuse and clean the two fuse contacts.
Use WD40 and gently scrape the contacts with a knife blade or metal finger nail file until they are nice and shiney.
Or simply replace each fuse with a spare. Same amp rating of course!
Good luck!
aznkorboi
10-13-14 05:38 AM
g356gear
IS F (2008-2014)
10-10-12 04:18 PM
Homchenko
SC- 1st Gen (1992-2000)
08-26-06 10:53 AM
Quick Reply: Help, No spark
