1990 LS400 Dash signals
Old 06-23-07, 11:15 AM
Meshblorg
Meshblorg's Avatar
Question 1990 LS400 Dash signals
For some reason when I accelerate a little red symbol pops up in the dash that says Brake on it with an exclamation point. I can't find what section discusses these things in my two volume repair manual.
In addition, my tailights and rear brake lights work fine but it displays my dash has an orange symbol of my car's tailights.
Also what does "L" do on the transmission?
Your help is greatly appreciated.
Old 06-23-07, 12:37 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
make sure e-brake is off and the brake fluid reservoir is filled up. if those dont help then u likely wore thru a brake pad.
Old 06-23-07, 02:41 PM
hobojoe
hobojoe's Avatar
"L" on the transmission stands for the low gear or first gear. standard on almost all auto transmission cars.
Old 06-23-07, 02:56 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Did you check all 8 brake light bulbs (6 for the trunk and 2 for the 3rd/deck brake light) to see if they all light up when you step on the brakes? What about the reverse lights?
And if those aren't it, then you need to replace the brake fluid level sensor.
Old 06-25-07, 03:28 PM
Meshblorg
Meshblorg's Avatar
Hmm thanks for the advice.
Also sometimes when I'm driving, when I press brake pedal to brake, the [R] for Reverse will light up in my dash scaring the hell out of me.
Old 06-25-07, 04:06 PM
Kansas
Kansas's Avatar
It sounds like you have a broken wire in the driver's side trunk hinge -- very common on the gen 1 LS. Do a advanced search of the LS400 section on "hinge" to see how to fix.
Old 06-28-07, 08:04 AM
Meshblorg
Meshblorg's Avatar
Trunk hinge?
Also sometimes for some reason the [R] for Reverse pops up in my dash when I'm pressing the brake. It scares the hell out of me and it makes the car slow down unsmoothly.
Old 06-28-07, 11:36 AM
PureDrifter
BahHumBug
Trunk hinge?
definitely a worn wire in the trunk hinge, thats a classic symptom.
flyfl1pguy
05-21-11 06:09 PM
UncleRay
11-25-07 08:40 PM
Dsc430
11-24-07 04:59 AM
anthracitetarga
SC- 1st Gen (1992-2000)
04-23-01 11:05 PM
Quick Reply: 1990 LS400 Dash signals
