Rear 18x10 Fitment Issues?
Old 12-15-06, 01:04 PM
AoyamaJPN
AoyamaJPN's Avatar
Default Rear 18x10 Fitment Issues?
Just wondering if there are any fitment issues for an 18x10 +44 wheel for the rear on a ls400. The fronts would be 17x9 +44. Also, what size tires you guys would you guys recomend?
thanks.
Old 12-15-06, 01:39 PM
chubby
chubby's Avatar
those wheel specs look fine. just make sure your tires are in spec
Old 12-15-06, 03:09 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what year LS is this for?
Old 12-15-06, 05:12 PM
AoyamaJPN
AoyamaJPN's Avatar
92 ls400
i found some real volks in my price range. only problem is they are 17x9 in front. 18x10 in back should be ok...
i am wondering about tire size...
Old 12-15-06, 05:57 PM
PureDrifter
BahHumBug
idk if i like the idea of a stagger on rim size (17+18) on the LS but i reserve my comments until i see pics.
i think that 18 is the bare minimum since the LS is such a big ****ing car.
Old 12-15-06, 10:46 PM
Brandicus
Brandicus's Avatar
if you lower it the rims will look bigger
Old 12-19-06, 02:18 PM
AoyamaJPN
AoyamaJPN's Avatar
so, i decided not to get those rims. i am going to be running 18x9.5 all around. what tire size do you guys recomend? 245-40-18 or 245-45-18?
Old 12-19-06, 03:30 PM
PureDrifter
BahHumBug
trust me on this, i have 245/40 and the speedo's off a bit and the smog machine *****es at me for having speed inconsistencies (passes though)
Old 12-19-06, 07:49 PM
trukn1
NELOC Mod
trukn1's Avatar
245/45/ will be a good tire choice. If you lower it then you will have to lower the tire profile to accomodate.
Old 12-20-06, 11:24 AM
chubby
chubby's Avatar
i had problems fitting my front wheels in 19x8.5+33. the spokes are not clearing the front caliper. i'd say it's more because of the wheel design. i am going to buy spacers and extended lugs in order to make it fit. hopefully this will give you an idea of how close you're working at.
Old 12-20-06, 01:56 PM
AoyamaJPN
AoyamaJPN's Avatar
Well, I plan to lower it about 1"... will the 245/45 combo work without rubbing?
Old 12-20-06, 04:57 PM
trukn1
NELOC Mod
trukn1's Avatar
[QUOTE=AoyamaJPN;2308064]Well, I plan to lower it about 1"... will the 245/45 combo work without rubbing?[/QUOTE
In all honesty I would drop down to 245/40 b/c that is the profile (40) I am running now; although I have 235/40 so my tire is not as wide as yours, however I am having no rub issues at all. My car is also lowered 1" on H&R springs. Not sure of 245/45 will rub or not, you may catch it going over large bumps and dips.
Old 12-20-06, 07:47 PM
skperformance
skperformance's Avatar
for an 18" on a 95-2000 model it is 235/50 18
Old 12-20-06, 10:17 PM
trukn1
NELOC Mod
trukn1's Avatar
He is running a 92.
Old 12-20-06, 11:10 PM
sc300tim5
sc300tim5's Avatar
im running 18x9.5s with 245/40/18s (sc) but still i wouldnt do the 45 series jus drop it and if your fenders need rolling roll em and run the 40 series u should be fine
Quick Reply: Rear 18x10 Fitment Issues?
