Boot on rack and pinion leaking, LS400
Old 10-20-06, 04:53 PM
goku2
goku2's Avatar
Default Boot on rack and pinion leaking, LS400
One of the boots on my rack and pinon is leaking and I want to know if it would be possible to just replace the boot or seal instead of getting a whole new rack. I was also wondering how much would it cost for the part and how difficult is it to remove and reinstall.
One more thing, some one on a forum mentioned that the powersteering has a filter that should be clean/changed otherwise it can get clogged and leak onto the alternator or something. How do I clean this/change this or what ever?
Old 10-20-06, 07:51 PM
pito
pito's Avatar
As far as the boot it comes down to how long its been ripped. How long has the inner rod been exposed to the elements?
Replacement of the boot usually requires some work anyway. I think its about an hour shop time.
Old 11-07-06, 01:25 PM
sbguyy
sbguyy's Avatar
Goku2
Bad news! My 94ls had this just happen.I was told the the boot is just a dust cover. If the rack starts leaking? The boot will hide it until it gets full of fluid. Then you see a leak from the boot. I went rebuilt. Cost about 400 dollars installed.
fergusor
06-08-17 05:34 AM
ihboy75
01-02-17 02:21 PM
Farino81
Performance & Maintenance
06-08-09 07:55 AM
mmccutchin
12-11-05 07:50 PM
Quick Reply: Boot on rack and pinion leaking, LS400
