Parking brake adjustment 98 LS 400
Old 01-22-06, 05:01 AM
jpdavis423
jpdavis423's Avatar
Default Parking brake adjustment 98 LS 400
My parking brake is not holding very well. Is there a cable that can be adjusted like the one on my Avalon or do I have to adjust the shoes at the wheels?
Thanks,
Jeff
Old 01-22-06, 06:44 PM
Tammy
Tammy's Avatar
It might be worth checking the rear shoes, but the parking brake is adjusted a little at a time at the point where the petal cable pulls the twin cables going to each rear brake drum. This way they are adjusted evenly. Mine is about under the left side, follow the brake cables. It's a double locknut affair that is adjusted.
I always adjust the parking brake with both rear wheels off the ground. This way I can just engage it by one or two clicks and check for even drag on both wheels.
Old 01-23-06, 10:26 AM
hyperopt
hyperopt's Avatar
Parking brake pedal should click 5-7 times when fully depressed, and if not, adjust via cable adjuster.
Old 01-23-06, 07:56 PM
jpdavis423
jpdavis423's Avatar
Is the cable adjuster the one that is described in Tammy's post?
Old 01-23-06, 08:25 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by rice h8r
maybe the shoes are worn? I think I have the same problem with our car, same year LS400. Even though the car doesn't move when in D and idling, the parking brake seems to be pretty weak...
Thats how its supposed to be from the factory.
Old 01-25-06, 04:25 PM
hyperopt
hyperopt's Avatar
Yes, located in front of the differential.
Old 09-28-19, 08:38 AM
JohnAndic
JohnAndic's Avatar
Parking brake on my 1998 does not release completely. I think it is just because of some rust build up but have to check it out. I guess JP never figured it out.
Old 09-28-19, 09:39 AM
deanshark
deanshark's Avatar
It might just be adjusted too much at the brake shoes, not the adjuster cable. You can try backing them off. Take the wheel off and you will see a small rubber plug on the brake rotor. If you take that plug out, turn the rotor so that hole is at the 6 O'clock position you can get a small screwdriver in there to turn the adjuster. I don't remember which way to turn it to back adjust them, someone will know and chime in.
Old 04-25-22, 03:50 PM
Joebago353
9th Gear
Joebago353's Avatar
The parking brake in my 99 LS 400 does not click and hold in the on position. Any thoughts on this?
Old 04-26-22, 05:37 PM
paulo57509
paulo57509's Avatar
Most likely, the problem is with the parking brake pedal assembly.
Some questions:
  • Does the parking brake hold the car in place if you leave your foot on the pedal?
  • Can you feel the parking brake apply after 5-7 clicks or does the pedal bottom out?
  • Does the pedal lock in place at any point in its travel?
TBH, I don't hear nor feel any clicks when applying the parking brake in my car. Yet the pedal ratchets and holds. Maybe I'm just getting deef.
Old 04-27-22, 06:54 AM
Joebago353
9th Gear
Joebago353's Avatar
The pedal goes down some, but no clicking and will not stay down. The brake does hold if I keep my foot on the pedal.
Old 04-27-22, 09:35 AM
deanshark
deanshark's Avatar
This shows the parking brake assembly that paulo57509 mentioned.
It must have something to do with the release cable for the pedal. How does the release cable feel? Is that kinked to where it could be not engaging and releasing the brake at all times?
Here's one on ebay. you can see what it looks like together. I'm not sure if the teeth are plastic which could be worn. https://www.ebay.com/itm/28302113936....c101113.m2108
Dupshaw123
IS F (2008-2014)
04-11-15 09:25 PM
LexaGlide
01-15-13 03:46 PM
Luke27617
01-28-12 10:25 PM
IStreefidy
Suspension and Brakes
11-14-06 04:37 AM
81corolla
RX - 1st Gen (1999-2003)
10-09-04 01:58 PM
Quick Reply: Parking brake adjustment 98 LS 400
