big rims,doing big thangs
Old 11-20-05, 03:25 PM
biglexass
biglexass's Avatar
Default big rims,doing big thangs
does anyone no if 22 inch rims can fit on a ls 400,or maybe 21 inch rims,cause if i get 20 inch rims there is still a gap,if i get the 2 ich lowering springs there is still a gap.i know some one out there has tried to put rims bigger than 20s on there ls 400s
Old 11-20-05, 03:39 PM
TJW98LS
TJW98LS's Avatar
22s look really stupid on an LS400 dude, take my word on it.
Old 11-20-05, 03:45 PM
TJW98LS
TJW98LS's Avatar
In addition to my last post, I have a couple questions...sorry for double posting...
I have stock chrome on my car. If I goto 18's, how greatly will it effect my acceleration??
True or False? If you go bigger than the stock rims, it throws off the speedometer a little bit.
Thanks guys.
Old 11-20-05, 04:11 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Any wheel thats heavier then the stockers is going to slow you down.
As long as you keep the same tire ratio, aka diameter, youre speedo will be correct.
Old 11-20-05, 07:40 PM
RA40
Super Moderator
RA40's Avatar
As Grand said...
Also the ride quality will likely become harsher with the added weight and shorter sidewall.
The stock tire/wheel on my '97 weighed in at 48#'s. The LSportline 18" and BFG 245/40-18 is 52 pounds. The 22" wheel I picked up was like 43#'s and adding in a 30 pound or so tire...the car will be very slow off the line. That extra mass will also not stop well and be a factor in additional brake wear. Not to mention gas consumption.
Old 11-20-05, 08:16 PM
TJW98LS
TJW98LS's Avatar
Originally Posted by RA40
As Grand said...
So, can you notice a different in your ride?? How much extra weight are your wheels Like 10 pounds??
Old 11-20-05, 10:21 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Yes, you will def feel a difference in the ride and handling. While handling will improve, braking and acceleration might decrease, depending on how heavy the rims are. Thats what makes forged rims such a plus. You get all the benfits and handling, without the added weight and stress.
Old 11-20-05, 10:45 PM
damon
damon's Avatar
Just been down this road.
I chose 18" SC430 rims on my 94LS since they are availble for a reasonable cost. Then chose Kumho SPT's in size 235/45/18's and I am very happy with the combo. I had to wait for this size to be introduced in the SPT tire but it was well worth it.
I had thoughts about 235/50/18's thinking the diameter difference would be minmal but am glad I waited. Staying close to stock diameter is important & a 45 aspect ratio gives enough comfort to keep me happy.
Downsides: The wheel swap has let me know audibly what I should have known based on the 178,000 miles I have rung up and that is that my Upper control arms are worn. Over poor quality sections of road you hear that hollow sounding thud.
Handling is vastly improved & I can't wait to get my Daizen sway bar bushings installed for further improvement.
Suspension work on my LS to date have been new oem struts at all 4 corners w new strut mounts in the front & replaced the Lower Ball Joints. Oops also have a Strut tower bar.
nomad
As for 22's: didn't want them not interested & can't even imagine how ****ty the ride would be.
Old 11-21-05, 02:20 AM
RA40
Super Moderator
RA40's Avatar
On mine the 4# difference was an obvious Suspension compression and rebound wasn't smooth. Handling has gone way up but the fine balance achieved with the factory wheels is gone.
A spring with a slightly higher rate would probably balance the additional rotating mass but then that gives a harsher ride. A lighter wheel tire combo would be nice but even some forged wheels don't have a drastic weight savings to balance their cost. One wheel I looked at from a solid billet after machining was 25 pounds for an 18" , the bare LSportline is 26 pounds. The design engineers assembled the suspension with a specific combination in mind and mods alter that.
All said, I enjoy driving the car and the give-take was as I had expected for the mods done.
Old 11-21-05, 07:44 AM
damon
damon's Avatar
I think I read in a post here that a stock SC430 rim is 37 lbs!!! The "star" centers do seem to weigh a little less than the "Pie Plates" btw.
The SPT tire in 235/45/18 is another 28lbs to make a total of 65 lbs per corner. Diameter is 26.3
A 94 LS has a curb weight of 3858.
Old 11-21-05, 03:31 PM
ychachad
ychachad's Avatar
18" is the most I'd go with on an LS strictly from an aesthetic viewpoint.
Old 11-21-05, 05:20 PM
ATSOU
ATSOU's Avatar
Hmm........I'm wondering the average age for those people who posted here
Old 11-21-05, 05:40 PM
RA40
Super Moderator
RA40's Avatar
This one has 19's.
This one is on 20's.
The Air Runner LS 430 is on 22's.
I chose 18's because that was what I felt was applicable for what I wanted at the time. I wouldn't mind a 19 and if timing is right, I'd do it. YMMV
Old 11-21-05, 09:02 PM
absolut
absolut's Avatar
22's would kill your ride bro. I wouldn't do it.
Old 11-21-05, 11:56 PM
Pagong
Pagong's Avatar
yikes.
Quick Reply: big rims,doing big thangs
