Traction Bleeding.
Old 07-12-05, 05:51 PM
Lexs400
Lexs400's Avatar
Default Traction Bleeding.
1990 LS400 with traction.
There are many many threads on how to bleed the brake system and references to the manual as well where it says that the master cylinder should be bled along with the traction system .
However nowhere in the posts does it mention how to run the traction pump so that the bleeder valve can be opened while the pump is running.
Could someone kindly post the method to bleed the traction system on the first gen LS400.
thnx.
AmericanLo
01-22-16 10:57 AM
ls40040lit
01-01-15 03:32 PM
phxls400
05-29-13 06:40 PM
Quick Reply: Traction Bleeding.
