timing belf & water pump
Old 06-20-05, 06:33 PM
RUDENESS
RUDENESS's Avatar
Default timing belf & water pump
what does it cost to do a timing belt and water pump for a 91 LS 400???????? gimme a dealer price and a reg, mech.
Old 06-20-05, 07:52 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
It cost around $850 for parts and labor at the dealer.
Old 06-21-05, 09:56 AM
GSquicksilver
GSquicksilver's Avatar
half the price at a local mechanic.
Old 06-23-05, 06:13 AM
ychachad
ychachad's Avatar
Actually, my dealership quoted me $1800 for water pump, timing belt and fan bracket.
Indy quoted me over $1,200.
Did it myself (PITA) for just under $400.
For you, water pump ($135) and timing belt ($40) will be under $200.
Old 06-24-05, 11:44 AM
damon
damon's Avatar
Replaced the following the other day & my labor cost was $400.00
This price included installing new front brake lines & pads.
Obvously the $400.00 was labor only. I had purchased parts over the last 30,000 miles.
13568-59045 Timing Belt
13540-50030 Tensioner
13503-0f010 Idler Bearing Left (round)
13505-50022 Timing Belt Idler Pulley Right (has mounting "ear")
Front Cover Gaskets
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
90311-A0001 Front Crank Seal
90311-38036 Cam seals ( 2 Total )
Cooling:
16100-50022 Water Pump
90916-03084 Thermostat
16325-62010 Water Inlet, Gasket
16571-50021 Upper Radiator Hose
71538 Lower Radiator Hose (Dayco Part #)
Hayden Fan Clutch #2656
16307-50011 Bracket Support for Fan
Accessories:
Alternator Parts
90099-10192 Front Alt. Bearing
90099-10194 Rear Alt. Bearing
27370-75060 Brush & Holder
5060885 Serpentine Belt (Dayco Part #)
89255 Tensioner (Dayco Part #) (This part was modified w grinder for proper fit/ use Toyota oem here!)
89026 Pulley (Dayco Part #)
Drive Belt Bearing NTN 63011LL (A&W Bearing)
Electrical
19101-50020 Dist. Cap X 2
19102-50020 Rotor X 2
Spark Plugs
BKR6EIX-11 X 8
94 LS 400
171,211 miles
Old 06-24-05, 12:52 PM
DoubleWhoosh
DoubleWhoosh's Avatar
Probably more like double that, and they won't do the 2 idler pulleys and the tensioners.
Total will close in on 2 g's
Should do the thermostat and the orings at the same time too
Old 06-24-05, 03:29 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
I'm guessing they didn't do the 2 idler pulleys and the tensioners because I only bought (at 25% off) a timing belt, water pump, and radiator hoses for them to replace. I didn't know more should've been done along with the timing belt and water pump...thanks for the tips Todd ...I'll definitely have to look into getting the rest done. Do you think you'll have any time for me in your busy schedule during the summer?
lexuslass
12-07-11 05:22 PM
iman61701
10-26-10 03:42 PM
mrchacon
14
07-29-09 05:13 PM
LEX012006
12-22-06 07:38 PM
Quick Reply: timing belf & water pump
