Sway Bar Bushings
Sway Bar Bushings
Does anyone know when the Diazen Sway Bar Bushings are going to be available for the 90-94 LS400s?
I'm trying to decide if I should buy Lexus OEM rear sway bar bushings ($60) or wait until these come out. Diazen said they were going to be available in September 04!
hello, for my 96 the energy part # is 9-5162G for the front ,the diameter of the front sway bar is 1 1/16 in or 27 mm and 9-5153G for the rear, the diameter of the sway bar is 9/16 in or 14 mm,,these are greaseable bushings,with zerk fitting for greasing it out, you got to modify a lttle bit for the front but for the rear its direct bolt on, i think RA40 (mike) has some pix for his ( mine is different ),
Problem 94'LS400 Rear sway 9mm
Energy Suspension doesn't carry anything that will fit a 9mm sway bar. Isn't that sad how small my rear sway bar is!!!
Pretty sure, 9mm! I took a wrench and tightened it on the sway bar then removed it and measured it.
Super Moderator
Mike-
Was looking at our data for the parts:
1 1/16" front bar part number is: ...............9-5162
9/16" rear bar part number is: .....................9-5153
Both of us listed the rear bar as 5/8" but the part # for 9/16" Sorry for the confusion guys.
You want the 9/16" diameter.
