Will 93 LS wheels fit 95LS????
Hi friends,
Will 93 LS wheels fit 95LS???? They have the same bolt pattern, 5-114
I Think 93 are 16 and 95 are 17 but dose that make any diff in fitment?
Thanks
Jigar
Thanks
Jigar
First, the 1995 also came with 16" dia. wheels, same as the 1993 and 1994. The bolt pattern is the same 5 bolts 114mm. However, the 1993 came with a 35mm offset, whereas, the 1995 came with a 41mm offset. The rear hub/brake of the 1995 is quite different from the 1993, so be careful before you buy, they MAY NOT fit. Try before you buy if you can. Another thing, unless you are getting a spectacular, almost for free deal, stay away from the 1993 wheels. You can often find 1995+ wheels which will fit your 95 LS perfectly for around $250 on the member classifieds forum. Look, wait, and you shall find them.
Originally Posted by 93LS
Hi friends,
Thanks
Jigar
Thanks
Jigar
Super Moderator
I'd do a test fit to be sure. While the bolt pattern and offset may be okay, I suspect the pre-'94 wheels will not have adequate caliper clearance. While 16" was the standard wheel size, the '95+ got the much larger 4 piston calipers. 17" was optional on the LS430's sometime about '02 I think.
