Wiper Blade
Wiper Blade
A very simple question - how do you remove the rubber wiper blade (not the entire assembly) for replacement? I have a 98 LS400,
thanks
thanks
Are you looking to just purchase & replace the "wiper refills"? This is the actual rubber that touches the windshield. If so use Mike's advice.
Now, If you're looking to replace the actual "wiper" (this is the refill with the rod that the refill slides into -this is not the arm that attachers to the body/cowl) then you have to pop up a plastic tab/prong in the middle of the wiper and then it should just pop off.
Hope that makes sense.
JASP615
GX - 1st Gen (2003-2009)
15
09-22-09 09:05 PM
