My ABS & Trac Light won't go off?? What could be the problem?
Old 04-18-04, 09:12 AM
DroppedGS
DroppedGS's Avatar
Default My ABS & Trac Light won't go off?? What could be the problem?
I have a 91 LS 400 and my Trac & ABS Light came on and now it won't go off. What could be the problem? When I push the Trac Light it doesn't do anything.
Old 04-21-04, 03:06 PM
mtsao
mtsao's Avatar
Default Re: My ABS & Trac Light won't go off?? What could be the problem?
You have a problem in both systems. Seriously though, do a search and you will find lots of threads aboout TRAC and ABS errors. Two things you can do:
1) Go to your dealer for a diagnostic (usually 1hr labor, so about $100)
2) Pull the trouble codes and post them here--many of us have factory service manuals and we can tell you what part of the system is acting up.
Being that it's springtime in most parts and there isn't snow on the ground, you probably don't have to worry about the TRAC system (until I decide to cough up $500 for the accumulator, I'm frequently driving my 90 LS with the TRAC light on) too much. I would be more concerned with the ABS.
Post your error codes once you pull them.
Old 04-25-04, 08:03 AM
DroppedGS
DroppedGS's Avatar
If my ABS computer is bad will my ABS & Trac Light come on? Are they 2 different computer for these 2 things?
Ps... Also my Anti-Lock Light comes on..
Old 04-25-04, 08:23 AM
Bercasio
Bercasio's Avatar
Default abs and trac light
For starters, check the physical condition of the battery (battery is warped? low volts?). People have a tendency to not look at the battery because it is in a enclosed area, and just as long as it starts and you have light, can listen to the radio etc. It gets overlooked, and how much constant volts are you actually getting? If its good enough for accessories in the car, the volts may not be good enough for the computer. Low voltage can create very false diagnosis, gettting to think in certain areas of the car may need maintanance giving you all these indicators of problems. Even when it is hooked up to the dealership's computer diagnosis system, it can fool that too!!! and they say, "well it will cost you $$$$, because the computer said so!" And they too will over look the battery. So start from there and hope for the best, otherwise go with the other previous suggestions. good luck!
Old 04-25-04, 08:27 AM
DroppedGS
DroppedGS's Avatar
Default Re: abs and trac light
I brought a Brand new battery last week. And its still on. What else could it be?
Thanks for the reply.
tom8757
12-15-12 05:51 PM
dannyypk
Maintenance
10-31-04 09:14 PM
Quick Reply: My ABS & Trac Light won't go off?? What could be the problem?
