my car is a gross polluter
Old 03-09-04, 02:06 PM
VicFerrari
VicFerrari's Avatar
Default my car is a gross polluter
well i went to get a smog check and it failed
like the CO (%) was 3.40 and a gross polluter is 2.05 and the max is .55
plus my check engine light was on so now i have to go down to lexus and get it fixed.. has anyone else had this problem and how much did it cost you to get it fixed... i have a 92 ls400
Old 03-09-04, 02:30 PM
buttons
buttons's Avatar
sounds like the 'cats' to me--not fuel related since that would be hydrocarbons.
The cat converter burn the CO and convert it to CO2 ,etc .
You said the CO was high--that should be it.
Old 03-09-04, 03:01 PM
VicFerrari
VicFerrari's Avatar
the HC (PPM) was high to 234
Old 03-09-04, 09:59 PM
LexmastrDS
LexmastrDS's Avatar
Default gross polluter
Vic,
more details are needed about your vehicle. Where are you located?
Old 03-09-04, 10:10 PM
VicFerrari
VicFerrari's Avatar
i am in southern CA
Old 03-10-04, 02:06 PM
LS400TX
LS400TX's Avatar
If you will do the diagnostics, usually CO is your o2 sensors (which you engine light will come on)
or EGR releated problem. Cats are usualy bad and will fail on HC and your engine light does not need to be on.
I just had that on my 92 ls400 in december.
U can try to decarbone your engine with RxP treatment. U can get it in Autozone.
Depends how much miles you have on the car, could be both.
Do the diagnostics as described either on WEB or in Service Manual.
just 2 c.
Old 03-10-04, 06:11 PM
VicFerrari
VicFerrari's Avatar
yah when i punch the gas getting in the freeway i can smell like surfur( cat. )... i know i should not take it to the dealer becuase they are going to chager up the wazoo, but i only have a little over 78,000 miles and i have rarely takin it in to get serviced becuase it is such a good, plus it is paided off for too.... after 10 years of leasing it YES 10 just don't ask...
JE5TR
12-06-10 05:40 PM
benz4matik
02-11-07 11:12 PM
BOBBYLEXUS
IS - 1st Gen (2001-2005)
11-19-03 05:23 PM
Losiho
04-24-03 03:41 PM
jpcdmd
Maintenance
01-30-03 08:16 AM
Quick Reply: my car is a gross polluter
