Strut bar w/air suspension
Old 12-31-03, 11:14 PM
LS_4Will
LS_4Will's Avatar
Default Strut bar w/air suspension
Hello Everyone,
I am wondering if the TRD strut bar for the supra would fit a 90 LS400 with air suspension. I am seriously contemplating purchasing one as the suspension on the LS is extremely soft even with sport mode and the 205/65/15 tires do not help the massive understeer. I need to know if it will fit and if so, with what modifications. Thanks. LS_4Will. Happy New Year.
Old 01-06-04, 02:44 PM
Lexkost
Lexkost's Avatar
Default Re: Strut bar w/air suspension
Originally posted by LS_4Will
Hello Everyone,
TRD strut bar will not fit you need an adjustable like this:
Attached Thumbnails Strut bar w/air suspension-strut-install.jpg
Old 01-06-04, 02:46 PM
Lexkost
Lexkost's Avatar
Wil look at this:
https://www.clublexus.com/forums/sho...5&pagenumber=2
Old 01-06-04, 05:04 PM
Rice
Rice's Avatar
Lexkost,
I am looking at the same stut bar on ebay. It's cheap enough, but I wonder if it's worth the hasle
Did you notice any change after you installed the strut bar?
Also, can you post specks of that ring you made, namely inside and outside diameter and how thick it is.
Thanks.
Old 01-07-04, 02:39 PM
Lexkost
Lexkost's Avatar
Originally posted by Rice
Lexkost,
Thanks.
The I.D. is 4" the O.D.is 6 5/8" the stud hole are 1/2 wide by 5/8 long and fabracated out of 1/4 thick aluminum plate................Or PM me and I will send you a template
When installing you must put tension on the bar to inturn apply that tension to the struts.......And yes you can feel a much tighter steering and less steering wheel movement over bumps...........MIKE
Old 01-07-04, 05:08 PM
LS_4Will
LS_4Will's Avatar
Thanks Lexkost for your replys. Is there any specific company I should be looking for? Will there be enough thread left because it looks like there isnt enough room for a spacer and strut bar bracket. Does anybody know a cheap machine shop in the bay area that can machine the spacer correctly? Thank You. LS_4Will.
Old 01-08-04, 05:49 PM
Lexkost
Lexkost's Avatar
LS_4Will, When will you be installing the bar?...............If I get the time I could make a pair for you I have some material left from the last pair I made...........Remember when buying the bar it should be an adjustable Supra TT bar with a slight bend on the ends of the bar.............................MIKE
Old 01-08-04, 08:10 PM
persian451
persian451's Avatar
heyman, all you have to do is search through the threads, the answers are almost always there: :-)
https://www.clublexus.com/forums/sho...hreadid=103394
i made it work, and i have a 91 LS400
Old 01-09-04, 09:43 PM
LS_4Will
LS_4Will's Avatar
Wow Mike, that would be amazing! that would be greatly appreciated...but please do not go out of your way in any way...whenever you time. I am not in any rush to get this done, but I am gonna get it done because I want it really bad. I just want to find the best deal. Thanks Mike!! LS_4Will
Old 01-30-04, 03:53 PM
Lexozz
Lexozz's Avatar
Hello Everyone,
No it will not fit! The dust cover that sits over the a/s struts in the engine bay is too high for the strut bar.
Old 01-30-04, 07:37 PM
Lexkost
Lexkost's Avatar
Default Re: Re: Strut bar w/air suspension
Show me a pic of your strut towers............and what stb did you try.
Old 01-30-04, 07:43 PM
Lexkost
Lexkost's Avatar
How much room is needed look at this:
Attached Thumbnails Strut bar w/air suspension-stb.jpg
Old 01-31-04, 09:46 PM
Lexozz
Lexozz's Avatar
This is the cover I,m talking about.
Attached Thumbnails Strut bar w/air suspension-picture-309.jpg
Old 02-01-04, 12:29 PM
Lexkost
Lexkost's Avatar
Your right ! But the cover has to be removed for strut bar and left off , no big deal....................Thanks Mike
Old 02-02-04, 03:23 PM
Lexozz
Lexozz's Avatar
I'm not so sure about that. There is important hardware underneath that can't take any dust. What I'll do is take the cover off to verify and more pics to go with that.
djrabbi
Suspension
08-19-15 07:43 AM
scstreets
Suspension and Brakes
12-08-12 07:18 AM
bigcory
02-28-08 12:37 PM
lexusguy
09-03-03 08:53 AM
krazyazzlexus
17
05-23-02 09:50 AM
Quick Reply: Strut bar w/air suspension
