Question on coolant & plugs for '95 LS400
Old 12-06-03, 07:46 PM
500amg
500amg's Avatar
Default Question on coolant & plugs for '95 LS400
Our '95 LS400 just went past ~62k and is due for plugs and coolant. Is there anything special I should be aware of? Does anyone know the specific procedure to get the air out of the cooling system after a flush and refil on the V8? Thanks!
Old 12-06-03, 08:27 PM
99lsguy
99lsguy's Avatar
For my 99,
You have 1drain by the T-stat area, 1 drain in lower engine block (drivers side), and passenger side of radiator (bottom) . Fill through FILLER PLUG on top of throttle body. top off radiator and reservoir and start car with heat on full for a few minutes. recheck levels and top off.
My manual also suggests de-mineralized water (2 gallons may be enough). I'd premix each gallon 50/50.
good luck
Old 12-09-03, 02:04 PM
500amg
500amg's Avatar
Hey, thanks so much for the reply!
kyk007
02-18-15 03:56 PM
GX470GT
05-10-11 09:22 PM
JBrewster
08-19-08 06:57 PM
LS4Lexus
Maintenance
11-11-04 11:50 PM
The Ikon
SC- 1st Gen (1992-2000)
30
05-31-02 02:04 PM
Quick Reply: Question on coolant & plugs for '95 LS400
