Chirping Sound From Speedo?
Old 12-05-03, 02:22 PM
lexchip
lexchip's Avatar
Default Chirping Sound From Speedo?
At low speeds I hear a chirping sound coming from the left side of the instrument cluster that slows down as the car comes to a stop. As I speed up the sound seems to disappear, although maybe the sound is simply obscured by the sound of the engine. It sounds like there is a cricket behind the dash. Could it be a speedo cable?
Old 12-05-03, 02:28 PM
Lexkost
Lexkost's Avatar
Default Re: Chirping Sound From Speedo?
[QUOTE]Originally posted by lexchip
[, although maybe the It sounds like there is a cricket behind the dash. Could it be a speedo cable? [/B
Here's your man!!!!!!!!
Old 12-05-03, 08:13 PM
BLexACK LS
BLexACK LS's Avatar
i think i may have the same problem, its more of a rolling chirp but not high pitched? am i right or is your sound different?
Old 12-06-03, 10:06 AM
lexchip
lexchip's Avatar
Default Rolling Chirp
That sounds like it. Hopefully one of the more technically inclined members has an idea.
Every time I drive the car I sit in virtual Lexus silence-except for that @#!*#! CHIRP!
Old 12-07-03, 06:17 PM
paradox
paradox's Avatar
Hmmm... my 95 LS was making that exact same sound, but at higher revs. Basically, it turned out the car was running too lean, and the buzzing/chirping sound was the computer attempting to compensate for the quality of gas which I was putting into my car (Hi Octance, but a local Georgia brand). I've since done an induction cleaning, switched to Chevron gas, and also trying to get into the habit of popping a top end cleaner into the tank every 5K miles or so....
Personal observation.... speaking from a placebo-less perspective (I think), Chevron really seems to make a difference in the car's performance... or maybe the other gas was just so crappy, anything would've been better by comparison. Also, I use the term "computer" generically. The tech had said if that component was bad -can't remember the name of it- buzzing noise would remain after you tried the above. Good luck!
Old 12-07-03, 07:49 PM
BLexACK LS
BLexACK LS's Avatar
well i don't think its the Gas because i pump Chevron and it seems for me at least to be more speed related then anything.
Old 12-08-03, 12:54 PM
lexchip
lexchip's Avatar
Default Chevron Solution
Thanks Paradox, but I hear this sound at low speeds. I have my doubts that a change in fuel will affect this problem. I am quite sure I'm hearing a mechanically generated sound possibly from a small gear driven assembly (speedometer?), not computer clicks.
Old 12-09-03, 02:41 PM
Rice
Rice's Avatar
There is no speedometer cable in LS. At least I hope not
wickedt
12-26-23 12:29 PM
gwblackbur
GX - 1st Gen (2004-2009)
09-29-18 10:39 AM
Sheriffen
04-20-17 06:04 AM
Sherwink
RC - 1st Gen (2015-present)
03-27-15 10:00 AM
GS42NV
07-06-07 06:59 PM
Quick Reply: Chirping Sound From Speedo?
