f-sport brakes, normal?
Hey folks. I'm looking at a CPO'd 2013 F-sport today and I was reviewing the service records.
I'm a little concerned about the brakes, based on what I've read here. I pasted the entire service record below, but the thing that concerns me:
1. at 9k miles brakes are noisy - lexus says they are fine
2. at 43k miles the front rotors are less than 3mm, so total front brake job
3. at 64k the rear rotors are resurfaced
is this normal for the brakes on an F-sport?
F-SPORT F-SPORT 2010 IS 250 2007 ES 350
PRINT
VIN: JTHBL5EF4D5117940
Filter History By Year
ALLAll 2016 2015 2014 2013
REPAIR# 0462810
REPORTED BY: Johnson Lexus of Durham
SERVICE: DENT WIZARD
DESCRIPTION: DENT WIZARD ~ ~DENT WIZARD ~ ~
SERVICE: INTERNAL FULL DETAIL- LARGE VEHICLES (LX & GX)
DESCRIPTION: INTERNAL FULL DETAIL- LARGE VEHICLES (LX & GX) ~ ~INTERNAL FULL DETAIL- LARGE VEHICLES (LX & GX) ~ ~
REPAIR# 0462596
SERVICE: 4 WHEEL ALIGNMENT
DESCRIPTION: 4 WHEEL ALIGNMENT ~ ~4 WHEEL ALIGNMENT ~ ~ ~ ~64081 1.8 1071 COMPLETED 4 WHEEL ALIGNMENT 1.80
SERVICE: BATTERY - REPLACE
DESCRIPTION: BATTERY - REPLACE ~ ~BATTERY - REPLACE LOW CCA ~ ~ ~ ~64081 .5 1071 190011 COMBINATION A 0.60 T1=72 T2=71 PERFORMED BATTERY AND CHARGING SYSTEM TESTS. BATTERY FAILED TEST, REPLACED BATTERY. OFP
SERVICE: CERTIFICATION
DESCRIPTION: CERTIFICATION ~ ~CERTIFICATION ~ ~CPO CERTIFICATION ~ ~64081 1071
SERVICE: CERTIFIED PRE-OWNED PDI
DESCRIPTION: CERTIFIED PRE-OWNED PDI ~ ~CERTIFIED PRE-OWNED PDI ~ ~ ~ ~64081 2.0 1071 COMPLETE.
SERVICE: FLOOR MATS TO BE PLACED IN THE TRUNK OF VEHICLE
DESCRIPTION: FLOOR MATS TO BE PLACED IN THE TRUNK OF VEHICLE ~ ~FLOOR MATS TO BE PLACED IN THE TRUNK OF VEHICLE ~ ~ ~ ~64081 1071
SERVICE: INFLATE TIRES WITH NITRO-FILL
DESCRIPTION: INFLATE TIRES WITH NITRO-FILL ~ ~INFLATE TIRES WITH NITRO-FILL ~ ~ ~ ~64081 .2 1071 NITRO FILL COMPLETE. 10/5/2016 #4205904
SERVICE: MOUNT AND BALANCE 4 TIRES
DESCRIPTION: MOUNT AND BALANCE 4 TIRES ~ ~LS460/LS600 TIRES 19 (4) 5/32 ~ ~ ~ ~64081 2.0 1071
SERVICE: NC EMISSION INSPECTION TEST
DESCRIPTION: NC EMISSION INSPECTION TEST ~ ~NC EMISSION INSPECTION TEST ~ ~ ~ ~64081 .5 1071 PASSED NCSE.
SERVICE: OIL AND FILTER - CHANGE
DESCRIPTION: OIL AND FILTER - CHANGE ~ ~OIL AND FILTER - CHANGE ~ ~ ~ ~64081 .3 1071 OIL CHANGE COMPLETE.
SERVICE: ROTOR, BRAKE (FRONT) - RESURFACE OFF-VEHICLE
DESCRIPTION: ROTOR, BRAKE (FRONT) - RESURFACE OFF-VEHICLE ~ ~ROTOR, BRAKE (FRONT) - RESURFACE OFF-VEHICLE WARPED ~ ~ ~ ~64081 1.5 1071 RESURFACED FRONT ROTORS.
SERVICE: ROTOR, BRAKE (REAR) - RESURFACE OFF-VEHICLE
DESCRIPTION: ROTOR, BRAKE (REAR) - RESURFACE OFF-VEHICLE ~ ~ROTOR, BRAKE (REAR) - RESURFACE OFF-VEHICLE WARPED ~ ~ ~ ~64081 1.5 1071 RESURFACED REAR ROTORS.
REPAIR# 0461099
SERVICE:
DESCRIPTION: THE BATTERY FAILED LOAD TEST -RECOMMEND TO REPLACE BATTERY $237.57 -GUEST DECLINED AT THIS TIME ~ ~VEHICLE INSPECTION SHEET ~ ~THE BATTERY FAILED LOAD TEST -RECOMMEND TO REPLACE BATTERY $237.57 -GUEST DECLINED AT THIS TIMEFRONT BRAKE ROTORS ARE GLAZED -SUGGEST TO RESURFACE BOTH FRONT ROTORS $241.21 -GUEST DECLINED AT T ~ ~GUEST STATES THAT THE BRAKES ARE GRABBING AND NOISY -PLEASE CHECK ~ ~ ~ ~64079 BRAKES APPEAR AND CHECK OUT OK BUT THE FRONT ROTORS ARE SLIGHTLY DISCOLORED SHOWING SOME OVER HEATING OF BRAKE ROTORS OR PADS. RECOMMEND RESURFACE FRONT ROTOR.FRONT BRAKE ROTORS ARE GLAZED -SUGGEST TO RESURFACE BOTH FRONT ROTORS $241.21 -GUEST DECLINED AT TA NONSMOKING LOANER CAR IS PROVIDED AS A COURTESY. IF NOT RETURNED BY 7:00PM ON THE DATE OF COMPLE ~ ~A NONSMOKING LOANER CAR IS PROVIDED AS A COURTESY. IF NOT RETURNED BY 7:00PM ON THE DATE OF COMPLETED REPAIR THERE WILL BE A DAILY $75.00 FEE. ***HAVE YOU REMOVED ALL PERSONAL BELONGINGS FROM THE LOANER?*** ~ ~A NONSMOKING LOANER CAR IS PROVIDED AS A COURTESY. IF NOT RETURNED BY 7:00PM ON THE DATE OF COMPLEA COMPLIMENTARY WASH HAS BEEN PERFORMED ON YOUR VEHICLE AS PART OF YOUR SERVICE EXPERIENCE ~ ~A COMPLIMENTARY WASH HAS BEEN PERFORMED ON YOUR VEHICLE AS PART OF YOUR SERVICE EXPERIENCE ~ ~A COMPLIMENTARY WASH HAS BEEN PERFORMED ON YOUR VEHICLE AS PART OF YOUR SERVICE EXPERIENCE
SERVICE: INSPECT FRONT AND REAR BRAKE PADS, CALIPERS AND ROTORS
DESCRIPTION:
SERVICE: INSPECT INSTALLATION OF DRIVER\'S FLOOR MAT
DESCRIPTION:
SERVICE: NOTE TO TECH /CHECK AND ADVISE
DESCRIPTION: NOTE TO TECH /CHECK AND ADVISE ~ ~GUEST STATES THAT HE ORDERED A WHEEL COVER FOR THE RF WHEEL -PLEASE INSTALL AND LEAVE OLD WHEEL COVER INSIDE OF THE CAR ~ ~
SERVICE: REPLACE ENGINE OIL
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL FILTER
DESCRIPTION:
SERVICE: RESET SERVICE INDICATOR
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
SERVICE: ROTATE TIRES
DESCRIPTION:
SERVICE: SERVICE - 65,000 MILES
DESCRIPTION: SERVICE - 65,000 MILES ~ ~SERVICE - 65,000 MILES (LEXUS PPM AGREEMENT 0022699472) ~ ~65,000 MILE SERVICE LEXUS PPM AGREEMENT 180 ~ ~64079 COMPLETED TECH# 628
REPAIR# 0449055
SERVICE:
DESCRIPTION: A NONSMOKING LOANER CAR IS PROVIDED AS A COURTESY. IF NOT RETURNED BY 7:00PM ON THE DATE OF COMPLE ~ ~A NONSMOKING LOANER CAR IS PROVIDED AS A COURTESY. IF NOT RETURNED BY 7:00PM ON THE DATE OF COMPLETED REPAIR THERE WILL BE A DAILY $75.00 FEE. ***HAVE YOU REMOVED ALL PERSONAL BELONGINGS FROM THE LOANER?*** ~ ~A NONSMOKING LOANER CAR IS PROVIDED AS A COURTESY. IF NOT RETURNED BY 7:00PM ON THE DATE OF COMPLEA COMPLIMENTARY WASH HAS BEEN PERFORMED ON YOUR VEHICLE AS PART OF YOUR SERVICE EXPERIENCE ~ ~A COMPLIMENTARY WASH HAS BEEN PERFORMED ON YOUR VEHICLE AS PART OF YOUR SERVICE EXPERIENCE ~ ~A COMPLIMENTARY WASH HAS BEEN PERFORMED ON YOUR VEHICLE AS PART OF YOUR SERVICE EXPERIENCE
SERVICE: DETAIL MGR. TOUCHED UP SCRATCHES AND CHIPS ON VEHICLE AS A COURTESY TO GUEST
DESCRIPTION: DETAIL MGR. TOUCHED UP SCRATCHES AND CHIPS ON VEHICLE AS A COURTESY TO GUEST ~ ~GUEST STATES THAT THE CAR HAS A NUMBER OF ROCK CHIPS AND LITTLE SCRATCHES -J. HUNTLEY TO HAVE DETAIL MANAGER FIX AS BEST AS WE CAN -SEE ATTACHED DETAIL SHEET ~ ~
SERVICE: GUEST ALREADY HAD THE KEY.
DESCRIPTION: GUEST ALREADY HAD THE KEY. ~ ~G/S THAT HE IS OWED A KEY FROM SALES FROM PURCHASE. ~ ~
SERVICE: INSPECT BODY PAINT AND CORROSION
DESCRIPTION:
SERVICE: INSPECT BRAKE LINES, HOSES AND CONNECTIONS
DESCRIPTION:
SERVICE: INSPECT DRIVE AXLE BOOTS
DESCRIPTION:
SERVICE: INSPECT DRIVE BELT(S)
DESCRIPTION:
SERVICE: INSPECT ENGINE COOLANT LEVEL
DESCRIPTION:
SERVICE: INSPECT EXHAUST SYSTEM AND HEAT SHIELDS
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT FUEL TANK, CAP, LINE AND HOSES
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT RACK AND PINION ASSEMBLY
DESCRIPTION:
SERVICE: INSPECT STEERING OPERATION AND LINKAGE
DESCRIPTION:
SERVICE: INSPECT SUSPENSION BALL JOINTS
DESCRIPTION:
SERVICE: INSPECT TRANSMISSION FOR LEAKS
DESCRIPTION:
SERVICE: MEASURE BRAKE PAD THICKNESS AND ROTOR RUNOUT
DESCRIPTION:
SERVICE: REPLACE AIR CLEANER FILTER
DESCRIPTION:
SERVICE: REPLACE BATTERY(S) IN MASTER KEY
DESCRIPTION:
SERVICE: REPLACE BRAKE FLUID
DESCRIPTION:
SERVICE: REPLACE CABIN AIR FILTER
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: REPLACE REAR DIFFERENTIAL FLUID
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 60,000 MILES
DESCRIPTION: SERVICE - 60,000 MILES ~ ~SERVICE - 60,000 MILES ~ ~60,000 MILE SERVICE LEXUS PPM AGREEMENT 0022699472 680 ~ ~59635 PERFORM SERVICE. 2.90 6727 SERVICE COMPLETE, FRONT TIRES AT 7/32, REAR AT 7.5/32, FRONT BRAKES ARE AT 10MM, REAR AT 11MM, ALL TIRES SET TO 36PSI, SPARE AT 45PSI.
SERVICE: VEHICLE INSPECTION SHEET
DESCRIPTION: VEHICLE INSPECTION SHEET ~ ~VEHICLE INSPECTION SHEET ~ ~ ~ ~59635 VIS. VIS COMPLETE.
SERVICE: \INSTALLED
DESCRIPTION: \INSTALLED ~ ~G/S THAT HE IS OWED WHEEL LOCK KEY FROM SALES. ~ ~
REPAIR# 0445370
SERVICE: CJM ENTERPRISES
DESCRIPTION: CJM ENTERPRISES ~ ~CJM ENTERPRISES ~ ~
REPAIR# 0444978
SERVICE: CUT AND PROGRAM ONE NEW MASTER KEY
DESCRIPTION: CUT AND PROGRAM ONE NEW MASTER KEY ~ ~CUT AND PROGRAM ONE NEW MASTER KEY ~ ~ ~ ~57341 PERFORM SERVICE .5 1071 PROGRAMMED A SECONDARY KEY TO THE VEHICLE. THE KEY SHANK IS A SOP PART AND WILL BE CUT WHEN IT COMES IN.
SERVICE: REPLACED A WHEEL LUG WITH /SOP FOR WHEEL LOCK
DESCRIPTION: REPLACED A WHEEL LUG WITH /SOP FOR WHEEL LOCK ~ ~G/S JUST PURCHASED VEHICLE RIGHT REAR TIRE MISSING A LUG NUT PLEASE CHECK AND ADVISE ~ ~ ~ ~57341 PERFORM SERVICE 1071 WE HAVE ORDERED A NEW WHEEL LOCK KEY AND SHOULD ARRIVE IN A FEW DAYS. INSTALLED A NORMAL WHEEL LUG UNTIL THE NEW PART ARRIVES.
REPAIR# 0727079
REPORTED BY: Johnson Lexus of Raleigh
SERVICE: AUTO INTERIOR - INTERIOR RECONDITIONING
DESCRIPTION: AUTO INTERIOR - INTERIOR RECONDITIONING ~ ~AUTO INTERIOR - INTERIOR RECONDITIONING ~ ~
REPAIR# 0726370
SERVICE: INTERNAL FULL DETAIL -SMALL VEHICLE (RX & SEDANS)
DESCRIPTION: INTERNAL FULL DETAIL -SMALL VEHICLE (RX & SEDANS) ~ ~INTERNAL FULL DETAIL -SMALL VEHICLE (RX & SEDANS) ~ ~
SERVICE: PERFORM ANTIMICROBIAL PROTECTION
DESCRIPTION: PERFORM ANTIMICROBIAL PROTECTION ~ ~PERFORM ANTIMICROBIAL PROTECTION ~ ~
REPAIR# 0726388
SERVICE: HUSKIE - VEHICLE RECONDITIONING
DESCRIPTION: HUSKIE - VEHICLE RECONDITIONING ~ ~HUSKIE - VEHICLE RECONDITIONING ~ ~
REPAIR# 0724656
DESCRIPTION: 4 WHEEL ALIGNMENT ~ ~4 WHEEL ALIGNMENT ~ ~ ~ ~56103 PERFORMED ALIGNMENT 6267-1.8 ADJUSTED TOE.
DESCRIPTION: CERTIFIED PRE-OWNED PDI ~ ~CERTIFIED PRE-OWNED PDI ~ ~Y ~ ~56100 CPO INSPECTION COMPLETE 6267-2.0 SEE REQ FOR NEEDED REPAIRS.
SERVICE: FIRST AID KIT
DESCRIPTION: FIRST AID KIT ~ ~FIRST AID KIT ~ ~ ~ ~56103 REPLACED FIRST AID KIT 6267-0.2
SERVICE: INSERTS, WIPER FRONT - REPLACE
DESCRIPTION: INSERTS, WIPER FRONT - REPLACE ~ ~INSERTS, WIPER FRONT - REPLACE ~ ~ ~ ~56103 REPLACED INSERTS 6267-0.2
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT REAR DIFFERENTIAL FLUID LEVEL
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: NC EMISSIONS INSPECTION TEST
DESCRIPTION: NC EMISSIONS INSPECTION TEST ~ ~NORTH CAROLINA STATE INSPECTION ~ ~ ~ ~56113 NCSE PASSED 6267-0.5 EMISSION TEST DUE TO MODEL YEAR.
SERVICE: NOTE SHIFTER IN SALES DEMP.
DESCRIPTION: NOTE SHIFTER IN SALES DEMP. ~ ~REPLACE SHIFT **** ~ ~ ~ ~56113 NO SHIFT ****, SALES HAS A **** 6267
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: REPLACE SPARK PLUGS
DESCRIPTION:
SERVICE: REPLACED DRIVER SEAT BACK
DESCRIPTION: REPLACED DRIVER SEAT BACK ~ ~REPLACE DRIVER SEAT BACK ~ ~ ~ ~56113 REPLACED DRIVER SEAT BACK 6267-0.5
SERVICE: REPLACED LEFT FRONT DOOR SILL PLATE
DESCRIPTION: REPLACED LEFT FRONT DOOR SILL PLATE ~ ~REPLACE LEFT FRONT DOOR SILL PLATE ~ ~ ~ ~56113 REPLACED LEFT FRONT DOOR SILL PLATE 6267-0.3
SERVICE: REPLACED LEFT FRONT PARKING SENSOR
DESCRIPTION: REPLACED LEFT FRONT PARKING SENSOR ~ ~REPLACE LEFT FRONT PARKING SENSOR ~ ~ ~ ~56113 REPLACED LEFT FRONT PARKING SENSOR 6267-2.0 CONFIRMED SENSOR IS NOW WORKING PROPERLY.
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
DESCRIPTION: SERVICE - 60,000 MILES ~ ~SERVICE - 60,000 MILES ~ ~ ~ ~56103 60K SERVICE COMPLETE 6267-4.9
REPAIR# 0718660
SERVICE:
DESCRIPTION:
SERVICE: INSPECT INSTALLATION OF DRIVER'S FLOOR MAT
DESCRIPTION:
SERVICE: NORTH CAROLINA STATE INSPECTION
DESCRIPTION: NORTH CAROLINA STATE INSPECTION ~ ~NC EMISSIONS INSPECTION TEST ~ ~ ~ ~53995 0.3-6000 PERFORMED NCSI-PASS
SERVICE: PADS, BRAKE (REAR) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE
DESCRIPTION: PADS, BRAKE (REAR) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE ~ ~PADS, BRAKE (REAR) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE ~ ~ ~ ~53995 2.0-6000 PERFORMED COMPLETE REAR BRAKE JOB.
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 55,000 MILES
DESCRIPTION: SERVICE - 55,000 MILES ~ ~SERVICE - 55,000 MILES ~ ~55000 ~ ~53995 1.0-6000 PERFORMED 55K MILE SERVICE
REPAIR# 0569181
REPORTED BY:
SERVICE: BLEND OR SYNTH LOF
DESCRIPTION: 8 CYLINDER FULL SYNTHETIC OIL AN D FILTER CHANGE ~ ~ ~ ~CHANGED OIL AND FILTER, TOPPE D ALL FLUIDS AND SET TIRE PRESSU RE
SERVICE: MULTI-POINT
DESCRIPTION: PERFORM MULTIPOINT INSPECTION ~ ~ ~ ~INSPECTION COMPLETE
REPAIR# 0219213
REPORTED BY: Hendrick Lexus Charlotte
SERVICE: *50K MILE HAG SVC
DESCRIPTION: *50K MILE HAG SVC ~ ~CUSTOMER REQUESTS A 50K MILE HENDRICK AUTO MAINTENANCE ~ ~CUSTOMER REQUESTS A 50K MILE HENDRICK AUTO MAINTENANCE ~ ~PERFORMED A 50K MILE HENDRICK AUTO MAINTENANCE PER CUSTOMER'S REQUEST LEXUS EXTRA CARE OP CODE LP9N35, CLAIM #TAC3DT6689
DESCRIPTION: 4 WHEEL ALIGNMENT ~ ~CUSTOMER REQUESTS 4 WHEEL ALIGNMENT ~ ~ ~ ~PERFORMED 4 WHEEL ALIGNMENT
SERVICE: MOUNT & BAL 4 TIRES
DESCRIPTION: MOUNT & BAL 4 TIRES ~ ~CUSTOMER REQUESTS MOUNT AND BALANCE 4 TIRES WITH NITROGEN FILL WITH CAPS. ~ ~ ~ ~MOUNT AND BALANCE AND NITROGEN FILL COMPLETE NEW DOT # HNYP NMLX 4012, 1015, 4914 X2
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~PERFORM MULTIPOINT INSPECTION ~ ~MULTIPOINT INSPECTION. ~ ~PERFORMED MULTIPOINT INSPECTION
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~FRONT BRAKES ARE AT 3 MM AND THE ROTORS ARE BELOW MIN. SPEC ~ ~ ~ ~PERFORMED COMPLETE FRONT BRAKE JOB REPLACED FRONT ROTORS AND UPDATED PADS
REPAIR# 0208862
SERVICE: *45K MILE SVC
DESCRIPTION: *45K MILE SVC ~ ~CUSTOMER REQUESTS A 45K MILE SERVICE ~ ~CUSTOMER REQUESTS A 45K MILE SERVICE ~ ~PERFORMED A 45K MILE SERVICE PER CUSTOMER'S REQUEST
REPAIR# 0669129
SERVICE: **NO WA******
DESCRIPTION: **NO WA****** ~ ~**NO WA****** ~ ~
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 35,000 MILES
DESCRIPTION: SERVICE - 35,000 MILES ~ ~SERVICE - 35,000 MILES ~ ~35000 MILE SERVICE ~ ~36925 35K SERVICE 1.0 PERFORMED - 635 - 6000
SERVICE: TIRES UNDERINFLATED N/C ADJUSTED ALL TIRE PRESSURES AS NEEDED INCLUDING SPARE
DESCRIPTION: TIRES UNDERINFLATED N/C ADJUSTED ALL TIRE PRESSURES AS NEEDED INCLUDING SPARE ~ ~CUSTOMER STATES TIRE PRESSURE LIGHT IS ON ~ ~ ~ ~36925 TIRES UNDERINFLATED N/C ADJUSTED ALL TIRE PRESSURES AS NEEDED INCLUDING SPARE - 635 - 6000
DESCRIPTION: VEHICLE INSPECTION SHEET ~ ~VEHICLE INSPECTION SHEET ~ ~ ~ ~36925 MULTI-POINT INSPECTION N/C FRONT BRAKES HAVE 3 MM OF PAD LIFE REMAINING - REAR BRAKES HAVE 4 MM - TIRES HAVE 5/32NDS OF TREAD LIFE - VEHICLE WILL NEED TIRES AND BRAKES AT NEXT SERVICE - 635
REPAIR# 0185118
SERVICE: *30K MILE SVC
DESCRIPTION: *30K MILE SVC ~ ~CUSTOMER REQUESTS A 30K MILE SERVICE BY THE BOOK 30K UNDER WL. SEE OWNERS MANUAL. ~ ~CUSTOMER REQUESTS A 30K MILE SERVICE TAC2ZH9510 TOTAL- 580.00 ~ ~PERFORMED A 30K MILE SERVICE PER CUSTOMER'S REQUEST
REPAIR# 0643535
SERVICE: GUEST DECLINES COURTESY WASH
DESCRIPTION: GUEST DECLINES COURTESY WASH ~ ~GUEST DECLINES COURTESY WASH ~ ~
DESCRIPTION:
DESCRIPTION:
SERVICE: PERFORM 4 WHEEL ALIGNMENT
DESCRIPTION: PERFORM 4 WHEEL ALIGNMENT ~ ~G/S THAT CAR IS PULLING TO THE RIGHT PERFORM 4 WHEEL ALIGNMENT AND ADVICE ~ ~ ~ ~19631 PERFORMED ALIGNMENT 1.8 TECH 3 TEAM 6000
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 20,000 MILES
DESCRIPTION: SERVICE - 20,000 MILES ~ ~SERVICE - 20,000 MILES ~ ~20000 MILE SERVICE ~ ~19631 PERFORMED 20K SERVICE LS460. 1.4 TECH 129 TEAM 6000 TIRES 7/32. FRONT BRAKES 4MM. REARS 6MM.
REPAIR# 0162096
SERVICE: *15K MILE SVC
DESCRIPTION: *15K MILE SVC ~ ~CUSTOMER REQUESTS A 15K MILE SERVICE LP9N10 ~ ~CUSTOMER REQUESTS A 15K MILE SERVICE LEXUS MAT. PROGRAM- TAC2WV0543 TOTAL-180.00 ~ ~PERFORMED A 15K MILE SERVICE PER CUSTOMER'S REQUEST
REPAIR# 0622606
SERVICE: BRAKES ARE OPERATING AS DESIGNED AT THIS TIME
DESCRIPTION: BRAKES ARE OPERATING AS DESIGNED AT THIS TIME ~ ~G/S THAT HER BRAKES SQUEAK ALMOST EVERY TIME SHE PRESSES THE BRAKES ~ ~ ~ ~9945 GOING TO ADDRESS THIS CONCERN WITH LEXUS FIELD TECHNICAL SPECIALIST. BRAKES ARE OPERATING AS DESIGNED AT THIS TIME
SERVICE: COMPLIMENTARY CAR WASH AND VACUUM
DESCRIPTION: COMPLIMENTARY CAR WASH AND VACUUM ~ ~COMPLIMENTARY CAR WASH AND VACUUM
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 10,000 MILES
DESCRIPTION: SERVICE - 10,000 MILES ~ ~SERVICE - 10,000 MILES ~ ~10000 MILE SERVICE ~ ~9945 MAINTENANCE 1.4HR 6796 COMPLETED 10K SERVICE
SERVICE: SET CLOCK
DESCRIPTION: SET CLOCK ~ ~G/S THAT SHE WOULD LIKE US TO SET TIME ON THE CLOCK ~ ~ ~ ~9945 SET CLOCK NO CHARGE CLOCK SET
REPAIR# 0612636
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: 5,000 MILE SERVICE ~ ~5,000 MILE SERVICE ~ ~5K MT ~ ~4729 COMPLETED TECH 2068 .6HR 5K SERVICE TIRES ARE 8/32NDS FRNT PADS ARE 8MM REAR PADS ARE 7MM THANK YOU
REPAIR# 0604002
SERVICE: RECLEAN FOR DELIVERY /LOT
DESCRIPTION: RECLEAN FOR DELIVERY /LOT ~ ~RECLEAN FOR DELIVERY /LOT
REPAIR# 0594336
REPAIR# 0591605
SERVICE: DETAIL FOR PRE DELIVERY SERVICE
DESCRIPTION: DETAIL FOR PRE DELIVERY SERVICE ~ ~DETAIL FOR PRE DELIVERY SERVICE
SERVICE: INSTALL NITROGEN/ INTERNAL VEHICLES
DESCRIPTION: INSTALL NITROGEN/ INTERNAL VEHICLES ~ ~INSTALL NITROGEN/ INTERNAL VEHICLES ~ ~ ~ ~13 NITRO .3 TECH 265 TEAM 5000. COMPLETED NITRO #2491384
DESCRIPTION: NORTH CAROLINA STATE INSPECTION ~ ~NORTH CAROLINA STATE INSPECTION ~ ~ ~ ~13 NCSI .3 TECH 265 TEAM 5000. COMPLETED NCSI
SERVICE: PRE-DELIVERY SERVICE FOR USA INSFUEL FILL
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA INSFUEL FILL ~ ~PRE-DELIVERY SERVICE FOR USA INSFUEL FILL ~ ~PDI ~ ~13 PDI 1.5 TECH 265 TEAM 5000. COMPLETED PDI.
© 2006-2016 Lexus, a Division of Toyota Motor Sales, U.S.A., Inc. All information contained herein applies to U.S. vehicles only.
Lexus Drivers
SERVICE SERVICE HISTORYF-SPORT F-SPORT 2010 IS 250 2007 ES 350
SERVICE HISTORY FOR YOUR F-SPORT
Get the most out of your Lexus Drivers account by keeping track of your vehicle service history. Work performed at an authorized Lexus Service Center will be added automatically. Any work done outside of a Lexus Service Center, can be updated or added yourself.SERVICE HISTORY
SERVICE HISTORY FOR: F-SPORTVIN: JTHBL5EF4D5117940
64082 MILES
DATE: 10/11/2016REPAIR# 0462810
64081 MILES
DATE: 10/06/2016REPAIR# 0462596
64079 MILES
DATE: 09/27/2016REPAIR# 0461099
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
59635 MILES
DATE: 05/11/2016REPAIR# 0449055
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: \INSTALLED
57342 MILES
DATE: 03/30/2016REPAIR# 0445370
57341 MILES
DATE: 03/22/2016REPAIR# 0444978
56114 MILES
DATE: 03/02/2016REPAIR# 0727079
56114 MILES
DATE: 02/29/2016REPAIR# 0726370
56114 MILES
DATE: 02/26/2016REPAIR# 0726388
56113 MILES
DATE: 02/17/2016REPAIR# 0724656
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
53995 MILES
DATE: 12/30/2015REPAIR# 0718660
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
48826 MILES
DATE: 10/13/2015REPAIR# 0569181
REPORTED BY:
43628 MILES
DATE: 07/22/2015REPAIR# 0219213
SERVICE: OTHERS
38849 MILES
DATE: 04/20/2015REPAIR# 0208862
36925 MILES
DATE: 12/18/2014REPAIR# 0669129
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
28751 MILES
DATE: 09/27/2014REPAIR# 0185118
19631 MILES
DATE: 05/16/2014REPAIR# 0643535
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
15001 MILES
DATE: 02/20/2014REPAIR# 0162096
9945 MILES
DATE: 11/05/2013REPAIR# 0622606
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SET CLOCK
4729 MILES
DATE: 08/06/2013REPAIR# 0612636
347 MILES
DATE: 05/23/2013REPAIR# 0604002
14 MILES
DATE: 02/27/2013REPAIR# 0594336
13 MILES
DATE: 01/31/2013REPAIR# 0591605
TERMS AND CONDITIONS
ABOUT LEXUS
FINANCE & LEASING
BRAND & LIFESTYLE
SERVICE
You have to look at what's here and what's not here: The multitude of attention to the brakes is a bit weird for most cars, but for some reason the Toyo brake hardware performs as indicated. So to answer your question, the data looks normal. If you're still at the table negotiate for brake labor using parts you provide.
Further, look at the service history and it's routine without any failures. Trim parts were addressed, but not too many complaints are in this car's history. Considering the information you provided the car is a good example of an LS.
