22" tire sizes
22" tire sizes
For the individuals running 22's what tire sizes are you running and does it scrub without modifying the fenders? I really what to see what series tires people are running and how they look. I want a little more meat than the 25 series that the rim shops recommend. Post pics please.
LS 460/600 Wheel & Tire Information Details Thread
A good place to start would be this long-running thread here where users post their specs with pics and would often note whether fender work was needed or if rubbing occurred.
Here's my 2 cents.
I have 08 L model with favtory air and lowering module. I had slits cut along the arch and rolled the rear fenders. I went with 25 series tires. I feel that I have room to go bigger. However, I then become taller than factory higher which would cause my odometer to be off. Maybe others can address this.
I also feel this is the right place to post this question. The other thread shares what others went with but don't address what the reality of going bigger than 25 series in the back are. If it's there, I missed it.
I might consider it when I need new rubber in the back.
http://www.1010tires.com/Tools/Tire-Size-Calculator
Keep overall outside diameter to within 3% to stock.
I have 255/30/22 offset 20 wheel is 9.5" wide and 295/25/22 offset 355 wheel is 10.5" wide.
But I think I can fit taller tire. Might make the ride better as well. I just put my wheels on, so I have time to figure it all out if I'd stay the same or change it up.
My Costco won't even sell the tires where the larger diameter rims are on the cars already because it isn't the factory rims sizes and yes the over all diameter is within 3%... Las Vegas, NV Costco.
