Data System Air suspension-English installation
Old 11-05-15, 09:27 AM
GAZA4Life
GAZA4Life's Avatar
Smile Data System Air suspension-English installation
Hey,
I'm looking to install my Data system on my LS but of course the equipment came with Chinese instructions. I've been searching through the forums and on Google for the last 2 days trying to find any english installation instructions but haven't found any. Does any one has the information in English or can assist with some help with the install. Trying to get this done ASAP..
Any info is greatly appreciated " In English"
Old 11-05-15, 08:54 PM
AMACK
AMACK's Avatar
me as well please thanks in advance.
Old 11-07-15, 04:46 AM
GAZA4Life
GAZA4Life's Avatar
Any HELP???
Old 11-07-15, 06:32 PM
SBlexus
SBlexus's Avatar
Take a look at Cjitty post!!!!!
Old 11-07-15, 07:09 PM
GAZA4Life
GAZA4Life's Avatar
Checked that...
Old 11-11-15, 12:56 PM
My1998LS40
My1998LS40's Avatar
Here you go. I got this from TriniGS. Hope everyone can use it.
NitroSupra (03-23-23)
Old 11-14-15, 05:18 AM
GAZA4Life
GAZA4Life's Avatar
Thanks a MIL.. I will update upon completion.
Old 01-09-20, 01:27 PM
AMACK
AMACK's Avatar
ok...here goes nothing!!!!
thanks for this, i am going in to tackle this now!!!!
Ill update if the cables for the 2008 will work for 2015 after I'm done>>>
Old 01-09-20, 04:52 PM
AMACK
AMACK's Avatar
All done. Very similar to the 08’ install. Although I didn’t do the speed wire in that one. So the removing the radio was new to me.
the main harness for the 08’ WILL work fine for the 15’.
the speed wire will not.
here are pics behind the radio and below the radio.
the final results show the car on setting 4.
Below the radio
Main harness
Setting 4 all around.
FreddyG (07-26-21)
Old 03-23-23, 09:03 AM
NitroSupra
2nd gear
NitroSupra's Avatar
Where in KS are you? Id pay if you install mine ; )
do you have pictures of the car? I just want 1/2 inch drop nothing crazy
Old 03-23-23, 10:37 AM
XF40FSPORT
XF40FSPORT's Avatar
If you're only looking to drop 1/2", have you thought about just adjusting the lowering links?
FYI Installing the data system unit only takes 30min max from start to finish
Old 03-23-23, 12:23 PM
NitroSupra
2nd gear
NitroSupra's Avatar
I thought about the lowering links but also like the data link option ..so to install the data link just behind the glow box its plug and play?
Any info on how to connect it via blootooth.
Old 03-23-23, 12:29 PM
XF40FSPORT
XF40FSPORT's Avatar
The unit I have isn't bluetooth, so I can't help you there.
Yes, just follow the instructions and it's plug and play. Just find the connectors identical size from the DS harness & it's self explanatory from there!
Old 07-06-24, 02:44 PM
Hosed
Hosed's Avatar
this guide was spot on. Took me about 15mins on my 2017 LS F sport
Rickochet
02-06-19 09:19 AM
peasodos
09-05-17 08:49 PM
hapaguy211
CL of Southern California
02-27-15 10:20 AM
SubieChik
Suspension and Brakes
02-26-14 01:51 PM
Quick Reply: Data System Air suspension-English installation
