Special TPMS for Custom Rims?
I purchased a set of 20" Savini rims and took them, along with the tires and these TPMS sensors to the Toyota shop to have them mounted and balanced.
http://www.ebay.com/itm/121420867494?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The service tech just called me and told me that because the valve stem mounts in the center, that I needed a different TPMS sensor that lies flat on the rim. He says that if I use these sensors, that if I have a flat, it will crush the sensor.
This is all new to me, so I thought I would ask if anyone else has ran into this problem, and is there a different sensor that I should use?
Thanks
Thanks
DP TPMS 4 Tire Pressure Monitoring Sensor TPMS Monitor 315 MHz w Aluminum Stem | eBay
Thanks
Thanks
I think Shibumi would as well...
Good luck!
Will this strap set work? If so, I will just order it. This will be easier than trying to find a shop that will drill the holes.
http://www.tpmsdirect.com/TPMS_Strap_Kit_p/8304-01.htm
Thanks
I personally don't recommend you buying the strap kit because those will make your tpms spin when the wheel rotates. I had this problem on one set of wheels and it would throw the wheel off balance. Best thing to do is find a shop that know how to drill extra hole for the tpms this way it'll sit perfectly on your wheel.
