2008 LS 460 - Self-Closing Door Problem
Old 09-17-14, 01:32 PM
larryhipsh
larryhipsh's Avatar
Cool 2008 LS 460 - Self-Closing Door Problem
My self-closing door feature on my driver door has stopped working recently. The other three doors self-closing door feature works flawlessly.
Is there an easy solution, such as a fuse? Or, does something else, more extensive, need to be done, i.e., should I seek out a professional mechanic?
As an aside, around the same time (if not the same time), my folding side mirror for my driver door stopped working. Any possibility they are related?
Thank you,
Larry
Old 09-17-14, 01:54 PM
dlbuckls10
dlbuckls10's Avatar
Time for a trip to the dealership.
Old 09-17-14, 02:05 PM
larryhipsh
larryhipsh's Avatar
Was definitely hoping to avoid the dealership.
Thanks!
Old 09-17-14, 02:25 PM
greg3852
greg3852's Avatar
I wonder if this thread may be something to look at..
https://www.clublexus.com/forums/ls4...ml#post8513104
Old 09-17-14, 02:53 PM
slimjimtel
slimjimtel's Avatar
That was exactly my thought...the door jamb switch.
I would start there.
Old 09-17-14, 03:11 PM
greg3852
greg3852's Avatar
How about not recommending the dealership to someone on their first post without offering some other assistance or letting someone else have an opportunity to help them first.
Telling someone to go to the dealership without any assistance at all is not what we are here for. If that was the case, no one would ever fix anything on their own.
Who knows now if this person will ever come back and see the suggestions we've offered.
Old 09-17-14, 05:12 PM
hfahmy
hfahmy's Avatar
Sounds like a fuse to me. Did you check the outside mirror fuse? Did you do any work on the door?
Old 09-17-14, 05:31 PM
CJITTY
CJITTY's Avatar
Fuse..there are multiple fuse boxes to check. One fuse shut down my entire rear systems including one door closer
Old 09-17-14, 07:28 PM
lieup
lieup's Avatar
Default door switch
Thank you,
Larry
Hello Larry,
My car has the same issue but on the rear driver side but mirror still function. What I noticed, if you open the door and if the courtesy lights is not activate; meaning your switch is bad. But if you wiggle the switch and the lights is On meaning your switch is bad too. You can try to swap them switch around and see if that helps.
Attached Thumbnails 2008 LS 460 - Self-Closing Door Problem-screen-shot-2014-09-17-at-7.19.18-pm.png
Old 09-18-14, 08:12 AM
jlawr
jlawr's Avatar
lieup,
perfectly helpful response, thanx for the pic
Old 09-18-14, 06:56 PM
Shibumi1
Shibumi1's Avatar
Theres a micro fuse in the trunk on the drivers side 5amp i think..it controls the closing curcuit an rear seats power and trunk light...i had this problem quick cheap fix
Old 09-18-14, 07:29 PM
cerbum
cerbum's Avatar
TIL: There's a self-closing door option for '08 LS 460's that I didn't know about!
I wonder if that can be retrofitted 6 years later....
Old 09-19-14, 04:56 AM
jmcraney
jmcraney's Avatar
Originally Posted by lieup
Hello Larry,
Defective Doorjamb Switches are a common problem on these cars and they can pose a serious safety risk. We have discussed this issue in several threads in this forum. Replacing the switches is inexpensive and a DIY project for many.
Check for discussions regarding the Doorjamb Switch here:
https://www.clublexus.com/forums/ls4...rning-off.html
https://www.clublexus.com/forums/ls4...e-the-car.html
https://www.clublexus.com/forums/ls4...ed-in-car.html
https://www.clublexus.com/forums/ls4...mb-switch.html
Old 09-22-14, 08:01 AM
larryhipsh
larryhipsh's Avatar
Damn you guys are amazing... gonna print this stuff out and give it a whirl when I have time this week.
Very much appreciated!!
Old 09-25-14, 05:38 AM
Chaos236
Chaos236's Avatar
dlbucks10 thanks for nothing
CJITTY thank you very much as I have the same problem!
Quick Reply: 2008 LS 460 - Self-Closing Door Problem
