brake Pad wear
brake Pad wear
the brake pad wear light just popped up on the car dash so i guess need to change the brake pads .. thats fine but i wanna get rid of the sensors which i beleive must be broke now ? as the light only comes up when the sensors break the contact on the circuit .
how many sensors are on the car for the brake thingy . i read some where its on the right side front and back need to confirm that .
is there a DIY for the brake bad replacement and sensor trick i read some where its just matter of cutting the wire and joining them with each other .
Thanks
Thanks
i drive daily about 200 miles all highway the pads do need a change because the previous owner changed them long long back
and still my question is not answered where is the sensor and how to get rid of it ...
The sensors are on the pads ,you'll see a wire leading to the pad. If you splice the wires back together the circuit will see the sensor as not broken. However you will not know if your pads are low unless you manually check it.
coming from a Evo 7 this car is like a gizmo machine
just cos every time i finish the brake pads don't want that message on my screen , not not head ache of replacing the sensor everytime
Not sure why you would want to hack up a Lexus like this and defeat the purpose that the sensor was intended for.
i feel sensors are not worth it i mean i will have brake pads changed about in 40000 kms again dont wanna change the sensor again
guys i need a bit of help , how do i make my fog light run independently ... like i dont want the head lights to work but only the fog lights , i read around best option seems is to route a wire and place a switch for it but how do i route it inside the car . i wanna do it my self
BTW for the brake pads i changed them still the warning is there the sensor wires seemed to look fine .
