ELM327 OBD2 - Which android app do you like?
ELM327 Bluetooth OBD2 Diagnostic Scanner let you check status of the car and can change the Lexus Personalized Settings.
So far I think only Carista App has been mention in our forum.
There are so many apps out there now, has anyone been able to play around between apps to give more feedbacks?
To me fancy interface might not be important on the smaller smart phone screen, but one that let your finger navigate around fast and easy. some app that let you customized your own data info layout which is also pretty cool.
Hi guys, just wanted to say that Carista is the ONLY app that can change Lexus Personalized Settings (LPS) This is our big distinguishing feature. Our other distinguishing feature is that Carista can check and reset fault codes in all Lexus ECUs, not just the OBD2 ones (engine, transmission, etc.) like all other apps do.
There are, however, lots of other apps that display real-time info from the car, which Carista doesn't do. "Torque" is the most popular one of those. It allows you to have a virtual dashboard with whatever gauges you want (subject to what data your car supports via the standard OBD2 protocol). There's also a bunch of other apps that can check/reset standard OBD2 codes and display real-time data, but I don't have much experience with them. Just search on Google Play Store, look at reviews and screenshots and decide what's best for your needs.
I have Carista app and I like it. I'm able to turn off the DRL through the Carista app and there are many other features as well that I didn't want to change the setting LPS. I also have Torque pro as well.
So far, Carista is the only app that gives you the capability to change the LPS...I've have tried other apps Torque pro, OBDII, etc...None of them gives you this capability.
Just a quick update: we've just released version 2.1 of Carista, which adds a bunch of new customization settings and more thorough diagnostics (we now support all Lexus ECUs, incl. ABS, airbag, etc.).
Ah, no, I guess I misspoke. When I said "all Lexus ECUs", I meant all ECUs in the supported models. (as opposed to the older version of the app, in which we didn't support diagnostics on some of the ECUs such as the ABS ECU).
BUT! Now that we're done with version 2.1, we are starting work on supporting Toyota's older protocol, which includes cars that had the C-Best settings. I can't promise anything yet, but... ask me again in a week
Do I have to use the carista module to use the carista app or any elm327 will work with the app? If that is the case will I still have access to all the ecus?
i'm using the carista app on my phone, and the obdII dongle is one of those $20 Micro Mechanics, "as seen on TV". works great for me. hope this helps
[QUOTE=Carista;8580220]Just a quick update: we've just released version 2.1 of Carista, which adds a bunch of new customization settings and more thorough diagnostics (we now support all Lexus ECUs, incl. ABS, airbag, etc.).[/QUOTE
CARISTA app doesn't support second generation lexus IS models 🙄
