19" or 20" Rims
Old 03-05-14, 08:08 PM
1Putt
1Putt's Avatar
Originally Posted by AznRacer
If I wasn't go to lower the car I think 20" will look good. I'm currently on 22" now and it's nice but the tires are a bit thin for me. So my next set of wheels I'm going to go with is 21" because I will be able to run thicker tires. But the wheels and tires selection are very limited.
I hear you...on 22 now also. I wouldn't change it, but if I ever was crazy enough to get a 2nd set it would be 21". If you go 21"- yes, tire brand choices and sizes are limited. However, you would have access to some jdm wheels that only go up to 21" (certain Work models). Still could go with the custom/made-to-order stuff (VIP mod, etc.), but I think maybe no 21" applications in brands like Vossen, etc.
Old 03-05-14, 08:11 PM
sydtoosic
sydtoosic's Avatar
Vossen is supposed to be offering 21's with the VPS wheels. i'm waiting patiently...
Old 03-05-14, 08:18 PM
1Putt
1Putt's Avatar
that'll be great, more choices
Old 03-05-14, 10:53 PM
CJITTY
CJITTY's Avatar
A 20" wheel with no lip and spokes that go to the wheel edge will look bigger than a 20" lipped wheel..if dropped it will look bigger in my opinion
Old 03-05-14, 11:56 PM
LXurious
LXurious's Avatar
20 inches would be perfect for the daily commute. With the air suspension on mine the ride quality from stock to 22's would be minimal the ride will still be better than nearly any car on the road. The only concern for long commutes and 22 inches you will run through tires twice as fast at least compared to stock, and since you most likely will want to go stagged you can't rotate your tires to maximize tread life. Also thinner tires on 22's are easy to bend with so little sidewall and the more time you spend on the road the higher the chance you can hit a pot hole which can do some damage.
Take that as consideration but not ride quality especially if you have the air suspension. If anything the tires you select will make the most difference too.
Old 03-06-14, 04:43 AM
PeteinPA
PeteinPA's Avatar
I do not have air.
As for the tires, if I go with the Conti's on a staggered setup I can at least rotate side to side.
I had the DWS's on my GS350 (19") and I was very happy with them.
Thanks for all your feedback CL, I think I know what direction to go in. Will post up pics once they are mounted.
Old 03-06-14, 07:58 AM
roadfrog
roadfrog's Avatar
Are you planning on lowering your car? If yes, I'd suggest a set of 21 inch or 22 inch wheels. If you do not plan on lowering your car then I'd go with 20's.
+2
We've had this discussion before and this is why I went with 20's in a staggered configuration. It's my daily driver doing significant miles and don't want the jarring ride. 20's are a nice compromise.
Old 03-06-14, 09:08 AM
Mitty
Mitty's Avatar
Originally Posted by roadfrog
+2
What's your stagger? What wheel and tire sizes are you running all around?
Old 03-06-14, 09:28 AM
roadfrog
roadfrog's Avatar
As you can see, I run a pretty aggressive offset. :
This is from the wheel/tire sticky at the top of the forum :
LS Year/Model: 2008 LS460
Wheel Brand: TSW
Wheel Model: Strip
Wheel Size Front: 20x8.5
Wheel Size Rear: 20x10
Wheel Finish: Gloss black w/polished lip
Lip size front (if applicable): 1"
Lip size rear (if applicable): 4"
Lip finish (if applicable): Polished aluminum
Offset Front: +20
Offset Rear: +25
Hub Bore size (if known): 72.5
Hub Centric Rings Required? Y/N: Yes
Tire Size Front: 245 40 20
Tire Size Rear: 275 35 20
Tire Make/Model: Falken FK452
Tire Air Pressure Preference: 38psi
Suspension: Stock non-air
Fenders Rolled/Altered: Nope
Old 03-06-14, 11:26 AM
korlexus
korlexus's Avatar
That's exactly what I thought.
McFlury
06-15-18 07:00 AM
Steven777
ES - 6th Gen (2013-2018)
03-01-18 06:30 PM
little2576
07-11-11 12:15 PM
AXChung
07-01-01 11:40 AM
GS - T.O.
05-16-01 07:11 AM
Quick Reply: 19" or 20" Rims
