Flat tire due to rim corrosion. Will it be covered under CPO warranty?
Old 01-04-13, 01:09 PM
Grouchy
Grouchy's Avatar
Default Flat tire due to rim corrosion. Will it be covered under CPO warranty?
I did some searching and found that people got their rims replaced by the dealer for rim corrosion. But I took my car to Longo where I purchased my CPO 4 months ago, and they informed me that it wasn't covered under warranty. Any thoughts on this?
I'm a bit confused with whats covered. Under the warranty it says rust and corrosion is not covered but what is the Corrosion Perforation Warranty then?
Old 01-04-13, 01:44 PM
Valley101
Valley101's Avatar
Default Flat Tire due to rim corrosion
Maybe goodwill fix, however, for the warranty to cover it you would have to prove where the rim was actually defective. Salt on roadways, living or frequent visits to areas where salt water bodies of water are present would or could cause the corrosion. Lexus standard rims are usually aluminum alloy and would not corrode. If you bought Lexus manufactured chrome rims the above might apply. If it is aftermarket, no way.
Old 01-04-13, 01:57 PM
nsaldanh
nsaldanh's Avatar
I had Lexus chrome wheels on a 2002 LS. After about 6 years the chrome started peeling off and the tire did not make proper contact with the rim. That led to air constantly leaking out. I was told by Costco (I use them for replacement tires) that this is a common problem with Lexus chromed rims. They had to put some kind of substance on the rim and then remount the tire. I am assuming that substance was some kind of adhesive. That fixed the problem. When you remove the tire you can see where the chrome is coming off. Even though it doesn't look like very much has come off that is enough for the tire not to make a good seal with the rim.
I can't speak to whether it's covered under a CPO warranty as my car was long past it's in service date by then.
As for me -- I won't be buying chromed wheels anytime soon.
Old 01-04-13, 02:02 PM
Grouchy
Grouchy's Avatar
I just received a call from the dealership and they informed me that they will be replacing three of my rims. I purchased the CPO with the chrome wheels chipping away but didn't think anything of it at the time. I guess I should have known better.
Old 01-04-13, 04:14 PM
RandyV
RandyV's Avatar
Swap the fourth wheel with the spare and you'll have four new-looking wheels.
Old 01-04-13, 07:19 PM
Lextrician
Lextrician's Avatar
eventually chrome will leak and bead seal will fix any leaks with a little grinding of the chrome on the inner lip where the tire seats.
SRP
RX - 3rd Gen (2010-2015)
12-24-12 08:27 AM
camberSC
CL of Southern California
11-10-08 05:58 PM
Fleainat
03-16-07 06:43 AM
swerve
10-07-01 11:35 AM
Quick Reply: Flat tire due to rim corrosion. Will it be covered under CPO warranty?
